Hi...I have surch this forum and all web trying to find some interconnect cables to use with Aleph-X and X BLS ...
I read somewhere that it's better to use long interconnectors then long loudspeaker cables...So I think that I will be needing something like 2x1.5m...but the problem is that I don't know much about cables...haven't opportunity to listen different types of cables
The problem is that I even can’t find some XLR type interconnects on market…All I see is Kimber Kable , like silver streak or PBJ and “sumic audio” silver cotton hand made cables which are like 1000USD / m ( well they are from silver )…
Can some one, please, recommend what brand of cables to use or to point in some direction???
Whell, what cables are you useing ???
Any help will do, because I am stuck here…
Josip
Josip
Josip,
at the moment I´m using Kimber PBJ for the balanced connection between X-BOSOZ and Aleph5. It beats my single ended Kimber select KS1030 and it´s not expensive.
william
william
In my experience, once you go balanced, cable differences become very minor. I would just get some decent pro quality balanced mic cable. In fact, as you don't need the resistance to handling noise that you get from real mic cable, you could just go for decent quality single pair + screen audio installation cable, costing about £0.30 a metre.
This is diyaudio -
yoke said:Try to DIY some cables. There are lots of pro grade connectors. Use three wires of what suits you. I like small guage solid core. Others like larger gauge stranded.
By making your own you can try different types of wire with the same XLR connectors. It costs as much or more to DIY some balanced cables compared to pro grade ready mades. Calbes are available for what four connectors cost.
I would have to agree that wire differences are reduced running balanced connections. One wire that is cheap is the long crystal Vampire magnet wire. It is about 10 cents a foot, and is about as good as any as far as quality.
George
Josip
If you are interested in building your own cables:
I had a mail this morning from Jon Risch, he has a site
with all you need to know about interconnects and speaker cables DIY made
>>Alain,
>>For balanced cables, see:
>>http://www.AudioAsylum.com/audio/tweaks/messages/25544.html
>>and consider using Belden 89207 or 89272 ala this portion of my DIY IC >>note:
>>http://www.geocities.com/jonrisch/i2.htm
>>Jon Risch
And I contacted TakeFiveAudio at takefiveaudio.com {canadian site}
they will store the Belden 89207 and it will be available on their site next week...
>>Do you have plans to store these cables ? preferably: Belden 89207 ?
>>Alain,I will get it on the site beginning of next week.
>>Regards,
>>Gene
>>I have a 130ft spool coming in late this week or early next, cost will
>>be $1.95 ft.
Only good news, I wanted to let you know... 😉
Alain.
>>Alain,
>>Jon Risch
>>Regards,
>>Gene
>>be $1.95 ft.
Alain.
I originally made my first set of cables with some balanced mic cable. These worked fine, however, about two weeks ago I got a bug and borrowed a set of AudioQuest Coral from the local hifi shop. To keep it short, the difference was huge. Now I just have a ****ed off wife when she saw the checkbook.
Scott
Scott
SGregory said:I originally made my first set of cables with some balanced mic cable. These worked fine, however, about two weeks ago I got a bug and borrowed a set of AudioQuest Coral from the local hifi shop. To keep it short, the difference was huge. Now I just have a ****ed off wife when she saw the checkbook.
Scott
*groans* Why oh why did I look in this thread? :-\ I use a pair of mic cables from Guitar Center. 🙂
Erik
I am using star-quad solid-core 22 gauge wire inside of Belden #8668 ground strap. It is very nice but the capacitance is too high for long runs and I haven't yet found a nice way to wind around a core to solve this.
Also time consuming to make. Anyone used those Proco Ameriquad star-quad XLRs?
Use good cables: I use Audioquest Pythoon XLR cable, and the difference respect the "old" AQ Lapis was clearly noticeable.
Marcello
Marcello
the new ones just came out, the DBS line 🙂 you should give those a try. i have my speaker cables coming in less than a week.
tortello said:Use good cables: I use Audioquest Pythoon XLR cable, and the difference respect the "old" AQ Lapis was clearly noticeable.
Marcello
mine
For speakers:
Warren Gregoire
XLR balanced interconnect:
AM-Systems
Use the gauge to your choice 🙂
Uli
For speakers:
Warren Gregoire
AM-Systems
Uli
I have an other one for you, in UK: Campaign Audio Design
http://business.virgin.net/cad.cables/wires.htm
Serious business. And good prices. 😉
Alain.
Alain.
Hi...thank you oll for yours answers and suggestions...Looks like I will have to go around and hear some cables before stick to any of them...
For the beginning I will probably buy , use , kimber PBJ , because they are not to expensive, and they will be something as reference...then when I got some time I will try to make some cables on my own ( I will try Belden )...and at the and will try that expensive cables ( like Audioquest , Kimber ...well maybe even «sumic audio» )...
By the way ...I have talk with mr. Sumic ,( Mr. Sumic is specialized in cable technolog , his cables got great reviews in croatian audio magazines , I think that you will not find any thing about him on net...maybe you will , I haven't ) who suggest me that , I should look for 4 connection cable , +, -, 0, and the 4th one for chassis ground ...That using 4 wire will give you best results ... well that's what he is using...
So thanks once again...If you have any other suggestion ,please, let me know...
Josip
Josip
teflon coated gold wire. Not even very expensive😀 😀
william
P.S. anyone tried the platinum?
william
Van den Hul D-102 Mk III Hybrid with your own choise of XLR(puresonic for instance). Sells for around 12 euro/meter off the reel.
Or:
Homebrew solidcore Silver wire with Teflon insulator.
see for instance: http://www.ae-europe.nl/toebehoren.htm (in Dutch, but I can translate if interested). Sells for 3,27 Euro/m 0,8 mm^2 (without insulating, but this will cost you another 1,25 euro/meter. Made like this (but than balanced):
http://www.triodedick.com/kabels.htm (also in Dutch, but plenty pics)
Or:
In an emergency I made up some balanced XLR cables using a similar method as the TNT Shoestrings: http://www.tnt-audio.com/clinica/shoestrings_e.html
Pins 2 and 3 were connected as per the Shoestring. For the shield (pin 1), I used the central copper wire from the coaxial TV aerial wire.
They seem to work fine, but are they balanced?
I have seen reference on this website: http://www.triodedick.com/kabels.htm that suggests using the outer braid for the sheild (pin1). I was being lazy by using the central wire. Is this a problem?
please god, do not let me go there...
Mine are made with Canare L4E 6S and Neutrik plugs. Very soft cable, and Neutrik are the best I've used.
Switchcraft's are a pain in the rear to assemble.
PS - there is no "e" in using.
I've been very satisfied with the results
L-4E6S BK Canare Star Quad Microphone Cable Per Foot List Price: $0.53 Our Price: $0.47
vs:
BL-1 4.00/foot
at 8 x the price you better be.
I use Tara Labs Air 2. I listened to a ton of cables before I drove off the cliff of DIY. I found that the Tara Labs stuff was the most musical and at each price point out performed the competition. In that I am referring to Kimber, straight wire, DH Labs, Audioquest, Cardas. Those were the ones I played with. But since driving off the DIY cliff, I don't much care to quibble with the slight difference cables make. I have some nice ones and I am done with that. I have found that better parts and better designs make more difference than the wire. What I mean by that is, I have a pair of $500 interconnects. I have a pair of $800 speaker cables. Great. My 150 chip amp sounds better than most $2000 amps. My F4's ,well they sound like F4's. At this point I would rather buy Black Gate caps and Ricken resistors (or substitute your favorite flavor of top notch parts) than spend that cash on boutique cables. I would likely get some nice OFC cable and make my own at this point. There is no real mystery to the whole cable thing and like all DIY you can get 99% of the quality for 25% of the cost.
- What XLR cables are you useing???
