what wire to lengthen at power supply leads??????
Lengthen Wires
Use the same size wire as a mimimum to extend the ones you have. Twist them together wel fold them over and solder them. Then slip over the appropriate size of heat shrink tubing , shrink it down and you is finished. Make sure that you are generous on the length the first time.
Mark From the colder farther north🙂
OK cool thanks, One more question, remember a while back someone posted a link to a AT power supply on Ebay that someone had made and It had some Nice silver and Blue tape covering the wire, what was that tape? also where do I get shrink tubing? thanks
It was probably just normal electrical tape that you can buy in several different colors (also from Radio Shack). If you don't want to mess with shrink tubing, you can use electrical tape. It's just not nearly as neat, nor as permanent, and can give you more hassle when messing with the adhesives. Shrink tubing is definately the more organized way of doing it, but I usually just use electrical tape for such things.
--Clint
