What watt? Why do we need all that power?
Dear Mr Pass! (or anyone else who might know the answers)
I'm new to this forum, and I might not have browsed previous messages well enough, so please excuse any repeated questions.
My knowledge of electronics is fairly limited, but I am a doctoral student in acoustics, so I know a bit about complex impedance and such. At the department I have built a low frequency wall of 15-inch woofers in a 4x4 matrix. I use a Lab Gruppen 1.4 kW power amp to drive it and it goes straight down to 12Hz. Or, to cite the honourable Mr. Pass: -"MuuuuHahahahaha……".
Now, in the specs it says that the amp gives 58 Vrms peak, over 8 ohms load. Loudspeaker impedance is rarely just resistance, but if it was, 8 ohm gives something like 7.25 amp, which gives about 420 W fed into the load. A loudspeaker is to the amplifier a complex impedance that depends on the radiation impedance of the woofer and tweeter, the crossover and so on. Is it common to have so low impedance that one actually needs an additional 100 W? What happens then to the loudspeaker? My 16 woofers can dissipate a lot of power due to their numbers, but for an ordinary loudspaker, isn't there a risk that something goues up in flames? Bob Carvers Sunfire subwoofers use a way too small box and a long stroke woofer. The small box means huge loss in efficiency, so he feeds some kW's into it as compensation. It gets really hot (I managed to trigger the thermal protection), but it's kind of built for it. Ordinary loudspeakers are not. In the Aleph 1, there are, if I understand it correctly, 40 IRF244's to get enough power out of it. I have just bought a subwoofer that needs an amp, and I was thinking of building one based on the Zen and Aleph articles by Mr. Pass. The subwoofer is kind of similar to a Sunfire in the sence that it has a T C Sounds long stroke 12-inch woofer in a relatively small box. Now, do I really need some kW's or is it enough with say 150 W like in the Aleph 1? Instead of using 40 IRF244, can one use fewer high-power FETs like the STE180NE10/STM (http://www.st.com/stonline/products/literature/ds/6872.pdf), given that they sound good?
I was given a 500VA toroidal transformer with 2x38V secondary for free, and It would be nice if it would be suitable for a amplifier for my subwoofer, but I guess it might be a little too weak?
/Anders
can one use fewer high-power FETs like the STE180NE10/STM, given that they sound good?
1) It is not uncommon for speakers to dip to low impedances,
so an amplifier with a high current capacity is sometimes a
necessity.
2) The presumption is that a speaker which demands high power
will accept it without damage. This is not always the case.
3) Later Aleph 1.2's used 24 devices per channel, and they
idled at about 25 watts each.
4) Neither the Zens nor the Alephs were actually famous for
deep and powerful bass. Their attractions were elswhere.
You might think about a version of the A75.
5) You can use higher power Mosfets. In the case of the part
you mention, it is rated at twice that of a 244, so you might
think of running it as high as 100 watts of dissipation if you have
a good heat sink.
6) I'm sure you could build a fine amplifier with that transformer.
Running balanced (bridged) you could maybe get a kilowatt in
peaks.
I realize this is the Pass Labs forum but your transformer would be perfect to use in a power supply for a UcD400.
Get some nice caps for cheap from Sander, some good rectifier bridges, other necessary parts and you've got yourself a power amp 🙂
There are more aspects to this than a leopard has spots. Some random thoughts:
--Low frequency wattage requirements are absolutely huge compared to midrange and high frequencies. It quickly gets worse if you use eq, a feedback network, or any of the other tricks people have tried over the years in order to get the carpet rippling.
--RMS or average wattages are one thing. Peaks are another. A good rule of thumb is to assume a 10:1 ratio between the regular listening power and the spike you'll see when someone does something rude...like hit a drum.
--The Carver sub plays tricks. So do the variations on the ELF concept, etc. See my first point, above.
--Class A is somewhat less important at 20Hz than it is at 1kHz.
--Few, if any, of these long throw woofers are anywhere near flat. They're modified boom-boom car drivers. Expect a very strong peak in the 80-100Hz region and be prepared to use eq to knock it out. Don't tell me what the simulations say, measure it.
Sixteen 15" drivers ought to be able to move a decent amount of air. I use twelve 12" drivers, not for volume (although I did cause some hairline cracks in the ceiling once), but because it greatly reduces distortion at normal listening levels.
Grey
As you probably know, this also largely depends on which driver you choose....the average HiFi bass driver of today lists an effeiciency or sensitivity of 85-90 dB SPL, whereas a lot of the pro drivers ( JBL, Pioneer, etc) will give you typically 96-100 dB for 1W/1m.... something to think about. ( listed levels not valid at sub frequencies , of course, -- just a guide line..)
I am personally fumbling around with parts and PCBs for several of the published Pass products, and I have the utmost respect for NPs work and maybe in particular his commitment to the DIY crowd (all my hats off!-- I actuallly have three!) .. NPs "open door" policy towards the DIY community is quite unrivalled on the High End designer side...
However, if your target is a subwooofer amp, the PassLabs forum may not be the right place to be, depending on which drivers you choose. Most amps in this section, except for the X-ed versions, have a fairly low efficiency, even if they are excellent amps.
A 2 x38V trafo will give you a standard class B amp of appx 200W +, which should be more than enough for a decent size driver and sub cabinet-- take note of the word "decent", - 'cause if you're trying to squeeze 110 dB at 20 Hz out of a shoe box, you will more than likely have to add an extra 0 behing the 8 on that trafo rating.
Use, say a 15" pro driver, a decent cab' - and you're back in NP land 😉
Thank you all for the sharing of knowledge!
Luckily I have access to a lot of mesurement equipment, so I will do as suggested and measure the properties of the woofer. I guess I can hook up the 1.4 kW amp to investigate impedance variations, especially with rude doings like stomping a kick drum. Isn't there a recording of 1812 with real cannons...? Then I'll know what power I need.
Have I understood it correctly that by using class A design, you avoid distortion due to the slight difference between the amplified positive and negative signal halves? Then I guess, as you say, I might as well go for a "AB" design and a low pass filter, because the distorsion will be of higher frequency than the original signal? But a push-pull design need a matched pair of MOS-FETs, doesn't it? By just browsing my local online electronics store, I find that there's plenty of N-channel devices, but very few P-channel ones, however they do have both the IRFP240 and the IRFP9240. Could I then use a whole bunch of these devices in parallell, like in the Alephs, to get enough output power?
If you plan to use the amp as a true sub-amp, there should be no need to sacrifice the efficiency of a straight class B for running AB or true A, as the distortion of the loudspeaker itself will most likely be a lot higher then the amp.
If by push-pull amp, you mean a bridged amp, you actually have a two channel amp driven by a balancing network to produce the push-pull action. In this case , and at these power levels, you will probably need several matched pairs, at least two, for each half of the bridge...
The IRFP pairs are good for PassLab clones, but I think your "local" supplier ( Elfa-?? ) also stocks the Toshiba 2SK1530/2SJ201 VFET pair, which is good for other designs. However, there is a rather hefty markup on the price of both types, - to my opinion.
Oh, yes, Elfa it is, and the price is accordingly high.
I guess I could find another supplier almost anywhere in the world that would be a lot cheaper, including p&p to Sweden.
By the way, I long ago bought some parts from a british supplier that specializes in out-of-production electronics parts, so if anyone really needs to find some of the original Zen or Aleph parts that perhaps are otherwise hard to come ny, the place to go might be: http://www.dialelec.com
Well, in the spirit of Mr. Pass. I'll use whatever I can get my hands on.
It's not the Thiele-Small specifications of the driver that are in question, it's the performance of the speaker as a finished system. All the T-S specs in the world will not tell you that the cone is breaking up. All the simulation programs do is present an idealized graph based on the T-S numbers fed into the formulas. They say nothing about such real world phenomena as non-linear suspensions or loss of flux due to heating of the magnet structure.
Grey
Indeed.
Forget the electrical impedances. Assuming no stupid tricks in a passive crossover, a woofer looks like a 6Ω resistor in series with the reflected mechanical load. The real impedance magnitude will never be less than 6Ω. In typical subwoofer duty, the mechanical resonance will raise the impedance, but you ignore that because most analysis assumes constant-voltage drive, and there will be some significant range where impedance is not much higher than 6Ω. You may be safe calling it ">8Ω"; that's what we usually do. FWIW, the maximum impedance is rarely over 50 ohms, and then only at one or two narrow bands; however impedance may be over 10 or 16 ohms over most of a subwoofer's working range.
If you build an effective (big!) horn, the transformed acoustic resistance will swamp much of the mechanical reactance. If cone and throat areas are similar, acoustic resistance reflects back to the electrical side as something like the electrical resistance: the 6Ω coil looks like 12Ω as long as the horn loads the cone fully (and up to the mass breakpoint). This will also happen in large arrays: put your 4x4 15" array in air or a vacuum (or connect every other driver out-of-phase), the impedance in the 40Hz-150Hz range will double when air loads the array.
NO! This only seems true because we (or our housemates) insist on using ink-dinky toy speakers. 50Hz is a 20 foot wave. Poking at the air with a 1-foot disk will NOT make much 20-foot slosh. Inefficiency is certain. Efficiency will be roughly the square of (cone-size/half-wavelength). One foot cone at 50Hz is about (1/10)^2 or 1%. (I am ignoring the slight narrow gain possible with bass-reflex: a Fifteen in a vented box can do 2% at 50Hz.)
If we stop fooling around, bass is easier than higher frequencies. Mass is a non-issue below 50-200Hz; coil mass kills any attempt to make middles or trebles. Take Hilbert's 4x4 15" array and put it in a doctoral student's apartment. At 50Hz, (5/10)^2= 25% efficient. Since hi-fi acoustic power is rarely over one Watt (maybe less in a small apartment with neighbors), 4 electrical watts should keep up with any mid-high system. At 20Hz, (5/25)^2= 4% efficient. Now we might need 25 electrical watts.
OTOH, a ten-inch trying to make 20Hz is (0.5/25)^2= 0.04% efficient. To make one acoustic watt reference, we need 2,500 electrical watts.
A Ten realistically doing one acoustic watt to 50Hz needs 400 electrical watts.
We have a choice: sixteen 15" speakers and 4 watts, or one Ten and 400 watts. Today, the cost of electronic amplification is much lower than the cost and space of large driver arrays. Even I have switched to a big amp and little woofers. But if you change your spots, big amps are quite unnecessary (though a larger apartment may be needed).
Only as a second-order. Driver SIZE determines low frequency efficiency. When you have enough size, other specs say how well the specific driver fits that theoretical limit.
> for an ordinary loudspaker, isn't there a risk that something goes up in flames?
The old E-V 30-inch woofer with styrofoam cone could catch fire. Paper is tougher to light. Used to be that the coil glue would melt, the coil winding shot off both ends like an explosion in a Slinky factory. Glue got better so then coils expanded from heat until they rubbed the pole pieces. One company puts Teflon on the poles so it can rub without sounding awful. (Heat dissipation improves markedly when rubbing starts, so this condition is semi self-limiting.)
The real reason we can run near-KiloWatt amps is that the peak/average ratio of most music is over 10dB. 400 Watts on peaks is 40 Watts average. The thermal time constant of a large voice coil is many seconds, enough to integrate the boom-da-boom. 40 Watts is not a large power in a 1.5" large-magnet coil, with modern glues.
Of course a single transient can over-travel the speaker. I've ruined my share of woofers that way. But modern heavy-duty woofers are very cleverly designed. The apex of mega-woofer tricks is enough suspension travel to let the coil mostly leave the gap (force goes to zero) and suspension strong enough to halt the cone inertia and bounce it back toward the working zone. They will survive really insane amounts of power more or less gracefully and with a low death rate.
No. A push-pull AB, B, or even a Class C amp can have equal (and equally distorted) positive and negative signal halves. That isn't a real problem, nor an annoying one, and Class A isn't necessarily better for that.
In the ideal Class B amp, at low signal level the device current is low, tending to zero. All devices (tubes, BJT, FET) give zero gain at zero current, and low gain at low current. So gain is small for soft sounds, normal for louder sounds. A Class B amp typically sounds OK when played slightly below clipping, but gets raspy at low levels.
The fix is to run a small current at idle, and use an amplifier topology where the gain equation looks, not like Rl/Re, but Rl/(Rl+Re). Re is the effective resistance of the device, and if we make Re<<Rl, the gain approaches unity, with very small shift for large change in Re. Example: a BJT at 100mA has Re about 0.3 ohms. 8/(8+0.3)= 0.96. If peak current is 3A, Re drops to 0.01 ohms. 8/(8+0.01)= 0.999. 0.999/0.96 is only a 4% shift of gain for a 30:1 shift in device gain and Re. This gets smaller in push-pull, smaller yet if we add resistors to limit the drop of Re at high current, and when you wrap a little NFB around it gets good enough for almost any audio purpose. (The hidden flaw is that when one side rises from 100mA to 3A, the other side drops from 100mA to 0.00000A, and when we come back near zero output current the hard-off side has to be dragged or kicked back into life. This is swamped by the still-on side, but sophisticated AB audio amps often try to hold the "off" side "slightly on" at all times.)
The Class A amp idles at half the peak current. Change of Re is small and cancels, though added resistance does not help. Neither device ever turns off (if it does, it is a hot AB, not a true A). And Class A can work with just one device (B and AB audio amps must use two devices).
On paper, an optimized AB amp shows lower THD than an A amp. But the AB will throw higher harmonics than an A amp, and probably more IMD, so A has virtue even though it is very hot/costly.
For a subwoofer: Fletcher-Munson prove that you won't hear soft bass, so low-level distortion per se is not at all an issue. An under-biased "AB" BJT amp may however throw 9th and 11th harmonics of inaudible bass decay, putting trash up in the midrange where you WILL hear it. A subwoofer amp must not be nasty, but does not have to be near as good as your mid/high amps. Class AB showing a trace of heat at idle is plenty good.
You're assuming that all comparisons are apples to apples.
Compare specifications on low frequency drivers and you'll find considerable variance in sensitivity/W. Worked out in terms of real-world requirements, it turns out that it takes an awful lot of power (and money) to get to 20Hz (or even 30Hz) with anything like flat frequency response.
Broadly speaking, you'll find two classes of drivers. One starts off reasonably flat, but rolls off in the 40-80Hz range. These drivers are generally quite efficient; at least low 90s dB, often higher. If you intend to go down to 20Hz it will take one to two octaves worth of eq to get there. (Watch the cone excursion--it increases by a factor of four with every octave and these drivers do not have much Xmax to play with.) As a result, the power requirement will go up. The other class goes much, much lower, but the frequency response is--to put it mildly--problematical. These drivers are generally at least 4-8dB less efficient, and require eq to remove the grotesque hump. In this case the eq isn't the problem, per se, it's the lower efficiency. Xmax isn't so much of a problem with these drivers. Keyword in sales literature: long-throw. A more subtle hint: lack of real, measured frquency response graphs--instead, they substitute T-S simulations since they don't want you to know about the uneven response. (And most people wouldn't know 20Hz if it bit 'em on the rump. If it vibrates the room, they think it's low, happy in their ignorance that it's actually 80Hz.) A non-subtle hint: the use of a melodramatic name for the driver such as The Blowhard, The Cat-Killer, or The Lease-Breaker.
I'm assuming that the driver in question in this thread falls into this second class.
If you're willing to stop at, say, 50Hz, your best option is the efficient driver with flat response, rather than try to pummel the "long-throw" driver into submission. You'll gain considerably in efficiency and can use a smaller amp. It's when you want something deeper that life gets difficult.
Grey
P.S.: I learned more than I wanted to know about this when I went with the Dayton Titanic drivers for my subs. Heed the voice of (painfully acquired) experience. I know whereof I speak.
If I had it all to do again, frankly I'm not sure which route I'd choose. Neither path is easy. And, yes, I demand real 20Hz response, not just simulations on a computer screen. Organs and such just don't sound right rolled off at 40Hz.
Butt-Buster, Neighbor-Knocker, or--if you're seeking a lighter, more romantic feeling (perfect for that overly sensitive significant other)--Heavenly Heartbeat.
Can you tell that I'm in the mood for alliteration?
How many names do you want? I can go at this for hours.
Seismic Shaker (okay, maybe that's a little too close to some of the real names), Richter Rocker...perhaps I should lay off the earthquake related stuff--they just had one helluva quake over in Pakistan and thousands are reported dead. Not funny. Put those names on the shelf for six months before using.
Ceiling Cracker (hey, I've got the cracks to prove it--twelve 12s will test your structural integrity with a Chinese Drum CD or Dafos 45 RPM vinyl).
Okay. Enough. I'm going to go listen.
Grey
EDIT: Speaking of names--I've always wondered about the "Pearl." There are many ways to look at that name, one of which (me being a tad cynical) is the old phrase 'Casting pearls before swine.' Or perhaps I shouldn't ask that in an open forum...
I'm not even in the apple store. Not all possible combinations of parameters are on the market, no. But Natural Law will NOT be violated, and can't even be bent much.
Sensitivity numbers should be taken with a shaker of salt. Some are taken above 1KHz and reflect directionality more than power conversion. Efficiency is a useful guide, and never a Big Text Spec so if it is quoted at all, it is usually correct. If not quoted, it can be derived from the usual T/S specs.
Grey, I've seen enough of your thought here to know that, despite a bad experience, you can and probably will understand it better. Sadly, coil+cone speakers were fully elucidated in 1927, all later research has clouded the issue, and nobody today seems to know why a coil+cone speaker can ever be flat over a decade of frequency. Neither the coil nor the cone is at all flat, but that's the key to serendipity.
> two classes of drivers. One starts off reasonably flat, but rolls off in the 40-80Hz range. These drivers are generally quite efficient; ... The other class goes much, much lower, but the frequency response is--... grotesque hump.
You are beating the bush close enough to see the tree.
Take a variety of drivers of the same size and varying efficiency. Tune them all the same: closed-box Q=1 is convenient, it does not matter. Plot them all at the same absolute scale. Ignoring a few poor performers (Qt too high for a Q=1 tuning, or just weak magnet), the bass-corner for all drivers of the same size falls on a 6dB/octave line. This IS the maximum efficiency possible for a driver of that size. If we want a flat broadband response, we pick a midband efficiency equal to the size-limited efficiency at the desired bass response. For a 15" in closed box, we can get 8% from 500Hz down to 140Hz, or 1% from 500Hz to 50Hz, or 0.25% from 500Hz to 25Hz. If the midband efficiency is not similar to the size-limited efficiency at the desired bass corner, we will get a slump or bump. A JBL 2222 (5%) and a Shiva (0.25%) will both have the same efficiency at the bass corner when tuned to, say, 32Hz corner; just that the 2222 rises from there and the Shiva falls. (I may be confusing Shiva with Tempest; whichever is 15" like the 2222.) And at the same bass frequency, both have nearly the same box volume (same if suspension were limp).
Go to 4-inch drivers and you find another 6dB/octave line, just shifted 4 times higher in frequency. There are a few 4" PA midrange drivers with efficiency near 4% but bass corner around 400Hz. For "full" range, a Four can't be designed higher than 1% efficient or it will sound gutless (it isn't gutless; the midrange drowns out the size-limited bass). Recent custom in Fours is to go to 0.3% efficiency for a gentle slope audible below 100Hz.
All our speakers are too small to make bass. It is not a fundamental design problem, we are just buying too-small speakers and making-up with monster amps. Back when a 15 Watt amp was "high power", theaters used 5-foot square radiating areas, horn-loaded to 2 or 4 fifteen-inch speakers. The area gave good coupling to 30Hz (the horn usually cut-off at 50Hz, all you need for excellent talking pictures). In modern PA practice, as in Hilbert's lab, we stack about 16 fifteens tight together, 5 foot square, and get good coupling to 30Hz, similar to a horn. Portability suggests box sizes that stifle response below 50Hz (more than you need for Rock) but such an array can be 20% efficient 50Hz-125Hz and 5% at 30Hz and 250Hz.
Instead of thinking in terms of home-size speakers, think in terms of the 20 foot wave you want to make, and big bass efficiency is easy. Only cost and size stand in the way. And because modest-efficiency speakers can array to high efficiency, and even 5% efficiency is "excessive" in context of 1% mids and tweeters, cost is not the killer issue in today's mass market. Radiating area and back-volume bigger than some apartments, and insane low prices for bulk BJT/FET power, is why we use teeny teaspoon drivers under 15 inches, and whine about huge excursion and all its ills.
Getting anything like the 5%-25% efficiency 30Hz-250Hz of a large array, at higher frequencies, is much tougher. In a direct radiator, 10% at 500Hz is excellent, and comes with problems. Compression drivers give leverage against motor mass, but they can't beat 10% at 2KHz or 1% at 10KHz. And even touching those points requires insanely heavy and costly motor magnets, and fun with midrange horns.
> twelve 12s
That's a good start in size. But a 12 designed to work alone broadband will not have low enough reference efficiency to work well in an array, and won't have a suspension limp enough to stay out of the way at 20Hz even with an infinite box. Dayton Titanic Twelve? It will be flattenable to 50Hz; perfectly reasonable for a solo 12. In infinite box, it slumps 50Hz down to 22Hz, and then falls bad. Probably needs over 12dB EQ to bring 20Hz level with 100Hz-200Hz region (not that you want an array that big working to 200Hz in a residential room!). The fix is to double the mass, sacrifice 6dB efficiency above 50hz for a few dB more around 22Hz, and then set the back-volume for optimum 20Hz output. And you "paid too much": 12 Twelves do not need 18mm and 500Watts to make all the 20Hz your home can stand. Short/small-coil small-magnet drivers would have worked, but there is no single-driver market for the parameters you need for a 20Hz array.
Why?
You don't need all that power. I built some ten watt amps and am very happy with them. Start small and work your way up if needed. Bi-amp if you need more bass. :smash:
Remember this site is for fanatics. Not too many people have a water cooled amp or put 4000 watts into el pipe-o.:bigeyes:
I don't know whether the problem here is too much theory or not enough. You're leaving out cone breakup (not that it's not subject to analysis, just that such information isn't readily available). That's part--probably most--of the hump in these drivers; the cones aren't very stiff. I wouldn't go so far as to call them rubbery, but they're, well, fairly floppy. Tap them with your fingernail and instead of a "tip-tip" sound, you'll get something more like "thup-thup." As near as I can tell the cones on these things have a purely mechanical resonance all their own. Granted, it's old hat to use cone breakup to extend the high frequency response, but this trick of pumping up the 80-100Hz range is another matter entirely. Note that I didn't say that there's any new science--just a purely cold-blooded marketing decision to tweak the response by peaking the driver in that range.
The flatter drivers give semi-predictable passband response in a normal T-S enclosure. The "long throw" drivers don't. Choose a maximally flat enclosure and what you actually end up with is a response that looks suspiciously like a Q of 2, 3, or even 4. Tolerable pass band response, by which I mean, say, +-3 or 4dB, followed by this great galumphing peak right in the middle of the same frequency range that boom-boom car systems, PAs, and disco-dance systems have taught folks to recognize as bass. So they go home and hear the same sort of thing and think it's wonderful low end.
Accident? I think not.
You say flattenable to 50Hz? The keyword here is 'flattenable.' I choose to interpret that word as "eq." The actual, measured corner frequency is half an octave higher. Or worse. I've seen some graphs online that indicate that some drivers in this class peak at more like 100 to 120Hz. These things aren't flat to 50 followed by a rolloff, they're so-so flat to 150, followed by a large hump centered (in my case) at 80, followed by a rolloff. 12dB of eq to get 20Hz even with 100Hz? Unh-uh...more like double that.
Again, I am not positing 'new' science, nor am I breaking any laws of physics. It's just a question of manipulating the cone material and thickness (read: stiffness), to produce a peak right where it would do the most good in the average consumer's mind. Cone-related response problems do not show up in any of the usual numerical specs. The only way they give themselves away is an actual plot of a real driver in a real test chamber...the very thing that the "long throw" manufacturers don't show you. Golly, what a surprise!
You came at this from the other side when you mentioned cone mass. Stiffness takes mass. A stiffer cone would be more massive from the git-go, and would satisfy both of us.
A decade of response? Perish the thought. I'd be happy to get from 15-20Hz to 40 or maybe 50Hz, where my Tympani woofer panels could reasonably be expected to take over. Unfortunately, the 80Hz peak is so pronounced that it fouls up the crossover slope something awful. The best you can hope for (short of applying a notch filter set for the peak) is to set the crossover slope for something around 40 Hz and hope/accept that the declining slope and the rising response will combine to something like flat response until the resonance has had its way with the driver and the whole shebang begins rolling off somewhere around 90Hz. That's almost an octave higher than I want to run these things, although others may have other ideas as to what they want from a 12" driver. Another strategy I've played with is to start with a more modest 16Hz LP filter that more-or-less flattens the response until the resonance gets done, at which point the LP slope takes over--but again, you're faced with a higher crossover point. This sounds good on paper but for some reason is unsatisfactory in practice, even if you make allowances for the higher than desired crossover point.
Paid too much? Maybe. Maybe not. When I got these drivers, they were, what, $130-140 ea.--I forget. The flatter drivers were going for double that or more. I seem to recall looking at a $280 driver and thinking that was pretty inexpensive by comparison with its peers. So which route is cheaper? As I said above, even knowing what I know now, I'm not sure what I would do if I started from scratch. The ones I've got now aren't chrome plated or anything--they're actually pretty pedestrian looking compared to the drivers out there now. They're just cast baskets with a big magnet (no Allen bolts or anything, just glue) and this silly talc-filled poly-something cone. Rubber surround, by the way. Foam surrounds are an absolute non-starter in my book. I absolutely hate self-destructing driver suspensions. Every year or two, they claim to have solved the problem of foam suspensions rotting, yet the stupid things persist in crumbling to dust within ten to fifteen years. (Grey, you're ranting about foam surrounds again...stop it...)(Oh...okay...)
Arguing theory is wonderful. Great stuff. Many pints of beer can be consumed during such discussions. But if you want to go that route, remember to add the cone breakup (dictated by marketing soft-science, another interesting variable) to your model. Please, quit arguing with me until you've investigated these drivers. You're assuming perfect or near-perfect pistonic behavior, and that's undermining your entire argument. You're where I was before I bought into the whole long-throw thing. I knew I was going to need to eq to get as low as I wanted and 15s were rare then (the few that were available were unacceptable due to foam surrounds). 18s? Whazzat? Given the need for eq, I knew I was going to need a large Xmax and so I went with Titanics. I kinda knew what I was getting into, and I kinda didn't. That peak threw me. On reflection, it's easy to see where they're coming from, but it makes life difficult for someone who wants high fidelity rather than boom-boom. Bummer.
And, yes, I think we can both agree that sometimes the published numbers are sometimes...ah...optimistic, shall we say...
Grey
Seems like I've stumbled upon a hot potatoe here...
End of the line for myself, though, is that I have the long-throw in a small closed box. I could of course sell it to some dB-dragster boom-boom head and buy something else, but (again) in the spirit of Mr. Pass I like to use what I have lying around. So I guess eq is the long and narrow path to take. And that calls for power, I guess, as I will have to compensate quite a lot here and there. Especially if I want it to go down to 20Hz. Without having measured anything yet, I would guess the resonance freq. of the system is a lot higher than 20Hz, and with a 6dB/oct roll off, I have to insert a lot of power. What I will probably do is measure input electrical power to obtain equal loudness down to 20Hz at highest requested loudness level, using all kinds of signals; noise, tones and transients. As mentioned one difficulty is influence of room modes. The anechoic chamber we have is only valid down to about 60Hz. However, we have another room which is of roughly same size and shape of an ordinay livingroom, and it is at least semi-anechoic, so I could probably do measurements there for a worst case rating.
Some time way off in the future I would like to build something from scratch, selecting drivers and designs carefully and spare little cost to obtain flat response down to 20Hz. Oh, and yes, in honour of my nordic heritage I would of course call it Tor (or Thor) - god of thunder. The upper frequency range could then be taken care of by the more subtle Oden's (Odin's) - god of wisdom. How's that for a name Mr. Pass? Although I really like "Butt-Buster" too. It wonder how that would appeal to the gay community.
As far as power goes, maybe I should build a three channel zen-like amp, with two channels being the very fine super symmetric class A's as described in the articles by Mr. Pass, and the third being a less subtle AB, B or whatever other design that could pump a lot of power. It should then be fitted with a switch to either run the two Zen-channels fullrange, or the Zen-channels above say 70Hz and the third channel below. Perhaps also a "pre-out main-in" connector pair to be able to apply that compensating eq.
The name? Well, Asgaard, of course - home of the gods.
On a related note, Mr. Pass, You seem to have a fablesse for MOS-FETs. Do you by that mean that one shouldn't bother with bipolars? I think we might have some old tubes lying around at the department, and I was wondering if they could supply the voltage gain and then utilize darlingtons for current gain? I guess the problem is that they require very different supply voltages...
Could there ever be a tube/hybrid Zen? Maybe the tubes won't allow for the Zen-like simplicity...
I like all gain devices, but exercises in minimalism have put me
in the Mosfet (and now power JFET) camp as they are the only
devices that lend themselves to single-stage power amplifiers.
After I wear out the single-stage thing, I'll probably get around
to re-visiting Bipolars and multi-stage amps.
I doubt, however, that I will do any tubes for public consumption.
There are still too many other people flogging that subject.
