Learned about these amp boards today. Most threads are about how cheap can they go but i want to know, how good did they get?
Which where the best finished in a box amps?
Using TDA7498L not tda7498E. "L" is for 6-8ohm speakers. Which is what is of interest to me.
https://www.st.com/resource/en/datasheet/tda7498l.pdf
TDA7498E is for 3-4ohm speakers. It’s not suitable for 8ohm. It can do more power into 3-4ohm speakers.
https://www.st.com/resource/en/datasheet/tda7498e.pdf
The TDA7498L 70w 10%THD into 8ohm matches the speakers I am getting/boxing a amp for currently 🙂, but for the 10% THD meh 🙂
This looks promising from YJ Yuan Jing Audio - TDA7498 digital amplifier (without power supply) - USD $67.50 - Finished Units
Not sure about the info. there other listings seam a bit messed up and missing info.
some have more large caps like this one. tda7498E???
or YJ’s very fancy version. built in dac.
Yuan Jing Audio - 24Bit / 96KHz USB DAC Power Amplifier [80w x2] TDA7498 + TE7022 + CS8416 + CS4398 + SGM8054 - USD $128.90
Yuan Jing Audio - TDA7498 Class-D Stereo Amplifier Board [100W+100W] + Switching Power Supply - USD $63.20 - Finished Units
sounds like tda7498L from the description. note not as many large caps.
