What tool do you wish you had bought sooner?
Those cheap wire strippers that are just a couple of pieces of black metal and yellow handles. You would not believe how much electronics work I had done stripping wire with knives or scissors.
Love my desoldering iron. I have a cheap one with a little rubber squeeze ball. Love it.
My table saw was a big step up. Gotta have it for speaker boxes and cutting aluminum sheet for enclosures.
I have had a Pace desoldering station now for over 30 years, but I do agree, it is probably the one tool I wish I had bought even earlier.
My pro wire strippers - field work, not a bench hot stripper - have been with me for decades as well, but I wish I had discovered them earlier
A 13-foot hose for my shop vacuum, purchased when the original 7-footer gave up the ghost.
Fully agreed.
An rechargeable LED headlamp.
If you mean the lamp you wear on your head, again, fully agreed.
A fiberglass scratch brush, wonderful for cleaning corrosion/oxidation from old parts prior to soldering.
And for reaching that spot between your shoulder blades when your wife, letter opener, or chop stick is nowhere to be found. :)
And I thought I was the only one crazy enough to cut sheet aluminum on a table saw. My shop teacher about had a cow when I showed him these pictures.
remember if he had all his fingers intact?
He was missing about 1/2 inch of his middle finger from a construction site accident when he was in high school in Kentucky.
I whacked a sliver off the end of my pinky trying to one hand a hedge trimmer while up on a ladder. It could have been worse, and most of it grew back.
a higher tooth count blade would have made a cleaner and safer cut
I had a better blade for the purpose, but it was an expensive blade for hardwood....I just decided to use the crummy blade that came with the saw.
