What to swap a 6AV6 for?
I would have thought you should be able to get 6AV6 from any of your US Suppliers.
If NOT then OZ supplier has them although price is about US$10 each.
http://www.evatco.com.au/index.htm
The 6AV6 is a triode + dual diode, That is, it is a high Mu Triode with 2 additional "diode" plates (anodes). The characteristics of the Triode are identical to each half of a 12AX7. You often see 6AV6 in older guitar amps, particularly in some Japanese Amps like Tiesco. They use the triode section and just leave the 2 diode plates unconnected.
Tubelab is correct in that a 6AT6 should work.
An EBC91 is also the same thing if you see that weird number show up on anyones listings.
Ian
