What to do with a 300VA 2x38Vac transformer?
I just purchased a 300VA 2X38Vac Plitron Transformer from a friend. He had purchased it for a junior design project but got one that puts out a bit more voltage then he wanted (forgot about the square root of two...). Now he didn't want it so I took it off his hands.
Any suggestions for the sort of power supply / amplifier combination that would be best for this transformer? For the DIY amps I've been looked at (Zen4, Gainclone, ect) they want a transformer with quite a bit less then 38V, hopefully someone has a suggestion for me to get the most out of the transformer or at least build something that's decent.
I'm going to be combining the amp with a pair of AudioReview DIY speakers
Thanks for the input
The 'traffo' (sorry didn't know the slang for it 😉 ) does have dual secondaries, the schematics at Plitron threw me off since it only shows it in series hooked up to 230V.
I'll also take a look at that P3A amp, thanks for the input!
Likely I'll be using it in series, so the schematic on the right but just 115 across the traffo.
