What are the options for a good project with the following specifications? I have four of them in hand. At the moment I am doing a open baffle 2 way Jordan with Jx53 and Jx150 with a ribbon super tweeter. Or should I sell them off instead?
Power==175W RMS
PEAK==350WATT
Imp==4 ohm
RDC==2.8 ohm
Fs==25Hz
Qes==0.62
Qms==2.9
Qts==0.51
Vas==248L(8.75cu.ft.)
Xmas==+/-6mm(0.24”)
Travel==1.1”
No%==0.627
BI=6.8TM
Mms==64G
Sd sq.M.==0.0531
MAGNET==56oz
SIZE==12”
Features
2" 2 layer voice-coil on aluminum bobbin
chrome ion deposited polypropylene cone with stress relief rings
Rubber surround
All the spec numbers means nothing to me at all, no clue!
Chris
Power==175W RMS
PEAK==350WATT
Imp==4 ohm
RDC==2.8 ohm
Fs==25Hz
Qes==0.62
Qms==2.9
Qts==0.51
Xmas==+/-6mm(0.24”)
Travel==1.1”
No%==0.627
BI=6.8TM
Mms==64G
Sd sq.M.==0.0531
MAGNET==56oz
SIZE==12”
Features
Rubber surround
Chris
Well, they sound like pretty decent drivers, good enough for a pair of push-push dipole subs....
BUT I think you'll have trouble integrating them with your JX150, which puts out pretty good bass in the Jordan factory alignments. I think you'll be happier with a setup where the JX150 is your LF driver.
On an open baffle ?
They sound like "free air" car drivers. Even in isobaric configuration
you'd need a sealed box of 4 cu for each pair.
Pretty good drivers for stereo open baffle subs though,
but this can get very complicated, see Linkwitz Labs.
🙂 sreten.
On an open baffle ?
My statement is still correct; Jordan does not have an open baffle factory alignment for the JX150.
http://www.ejjordan.co.uk/systems_frameset2.htm
OK, I'll rise to the bait, correct but totally pointless in context.
🙂 sreten.
I think the output of 4 x 12" drivers with such a small xmax will be marginal. Sealed or vented they will have reasonable output. You need a lot of displacement to get any real output of a dipole!!!
paulspencer said:I think the output of 4 x 12" drivers with such a small xmax will be marginal. Sealed or vented they will have reasonable output. You need a lot of displacement to get any real output of a dipole!!!
Displacement means diameter of the 12" or horizontal movement of the diaphragm along X-axis?
mount them in the floor... I did it with a single 10inch driver, and the bass was the best.. lol for a $35 10inch woofer with 3mm x-max..
If I want to use it in the basement that means I have to dig a hole in the concrete foundation in order to mount them in the floor. That may be too much work to smash thru the foundation. What about paper/cardboard tubes? Any suggestions?
If you use cardboard tubes you need two around 6 feet tall.
Use a pair of drivers in clamshell / isobaric configuration per tube.
Stuff well and you'll get a Q of around 0.7 at 35Hz.
🙂 sreten.
🙂 sreten.
displacement is the swept volume of the driver, multiply the area of the cone by the xmax, max ecursion of the driver.
- What to do with 4 12inch woofers?
