what to do whit this
Hi
I have alot of nice parts under my bed 🙂
40 pcs of Rifa PEH169 15000uF/40V
100 pcs IRFP450 from Harris
A new toroid 2x21V /1000VA
So what can I make of this ?, i have been thinking of a 5CH amp but i cant find any circuts that i can use my parts in..
Iam thankfull for all the help i can get, and sorry for my spelling 🙂
homemodder said:
I think you should make trip over to passlabs forum, that is if you like class a Amps. Put this same question there.
class a amps are lovely, and i have already built one Aleph amp, but they have one big problem and its the heat , i dont want to use big heatsinks and fan's to keep it cold, so a class a/b or just class b will be good for me 🙂
Re: Need more cowbell
wg_ski said:
Or secondary voltage to be really useful. Can you add turns to the secondaries, or is it potted in the center?
Sure i can add more turns, the sec voltage is low, but i cant step over 40vdc , since my caps are rated 40v and i want to use them .. guess whit a sec of 21v it will give me about 30vdc, so i can add som turns mabe take it to 35 vdc
No forget class H, stick with A or AB - they sound best.
So you want:
- higher voltage /power than from 21v sec
- class AB
- N-channel FET output (quasicomplemntary)
My suggestion is:
Make 10 of the "Legend" by Dr. Bora ( use the search function)
and drive your 5 channels balanced.
It would be an effektive use of most of your nice parts
...allthough with 5x200-240W per channel you might be pushing the toroid at full power. So drive the front L and front R balanced meaning 'only' 7 amplifiers.
...and if you have 8 leftovers caps, then I could sure find some use for them😀
