What to do.. Build Aleph JX or F5T V3 monoblocks?
why not build 2 amps? aleph 5 and F5 turbo v2 can use the same PSU and chassis.
make and easy swap amp bord system🙂 or aleph 2 and F5 turbo v3 if you are building big monoblocks.
aleph 3/30 and aleph J and standar F5 can use the same PSU. the amp boards with components are not that expensive.
either JX or BA3 Bal
I agree with Zen Mod - Aleph JX or BA-3 Balanced with lot of outputs.
Or a 'straight' Aleph, like the 5.
I've got an Aleph 4 and it is really a delight to listen to. I find my F5 quite tiresome after a short time.
my decision for you is build the AlephJ
...but i think all here know your dilema to much amps to build and all are good 😀😀😀
but if you listen much to metal hard rock techno (fast musik) then you maybe should also think about the f5
my experience was the alephJ was to relaxed for to fast music
god thanks i have both so i can switch😀
There , I'm glad thats settled .... 🙂
AudioSan:
You're right... Thé J-X and A-X can use the same psu, 2*18-22V@6-750VA.
Then the F5V3 and A2 can use the same psu, 2*28-32V@750VA..
It seems like I'll have to build me a pair of either A-X or A J-X 1-125W monoblocks..
it seems like the A-X is an easier build with regards to info on hand and the number of completed builds..
I have sinks enough to build 2* 0,06c/w monoblocks and 1* 0,95c/w stereo amp, ie 2*50w, so the solution might be to build 2* A-X Monoblocks and then a stereo amp to use as amp for the mid/ tweets/testing different amp projects. If I don't like the A-X monos, I'll try the aleph J and if I like it, I could build the Aleph J-X monos instead..
So, the Aleph-X it is..
What rail V should I use and what Bias A for maximum performance into 6-8R speakers?
They are 6R almost trough the whole register, but are 8R nominal speakers, Thé Elsinores is the speakers I'm building at the moment.
As I'm on my phone writing this, as my pc is dead, I can't really check the AX-1.2.zip file to see what V and Bias gives best performance for my speakers, could someone be kind enough to check it out fir me?
Before my pc died on me, I remember I could get almost 150w @8R and 200@6R with my sinks, I must have got something wrong, right?
I remember I just clicked until it seemed okey and it was optimized in 6R operation, but could it be right?!
Sorry for my weak spelling, I'm tired...
//M
