If you get 0 ohm between pin3 and pin7, it looks like you have a short circuit between pin 3 and the V+ rail of your supply. Thus, you will have 35.5Vdc at your speaker output terminal.
check carefully that no stray wire or whatever connects your V+ and the pin3.
regards.
