i havent soldered since i was a kid. i really dont know what tin wire to get for soldering my 3way crossovers, or how much i need.
would a 17g pack like this be enough? ROLLO DE ESTAÑO PARA SOLDAR SIN PLOMO HILO 1mm TUBO 17g ELECTRONICA ELECTRICIDAD | eBay
its a spanish seller so the shipping woould be very cheap.
thanks for help 🙂
thanks for help 🙂
17g is enough as a sample to find out if you like the flux.
Once you have decided on the flux you want, then buy 500g reels in two or three sizes to last you a few years. and make sure all of them have lead in them. It's better with lead and as a eutectic.
I am happy with this one: (link)
- 450 g
- 63% Tin, 37% Lead
- Rosin core
- 0.020" diameter (0.5mm)
- Kester 44
That's the stuff I use...I like it. I've done quite a bit of soldering and found that the lead free solder is a pain in the butt to use.
would this be better suited? its 63/37 0.8mm and is flux cored
100gr roll
ESTAÑO 100GR 0,8 MM FLUX 2.0% ROLLO BOBINA SOLDADURA | eBay
100gr roll
ok.. now finally everything i need for the build has been ordered, including new amp, cables and a lot more.
only thing left to finance when its time is the finishing... i still have no idea how much the veneer will cost..
also audikit.it has sent to me 2 replacements for the broken coils, i suppose i will receive them this coming week.
- Design & Build
- Construction Tips
- what solder to use? tin with lead or no lead??
