What should I build - have 2sk60 (4) and 2sj18 (4)
So I did not win the v-fet lotto and i'm trying to make lemonade out of my lemons.
I happened on a working / fully functional (measures good) Sony TAN-5550. I was going to just do some updates (caps, diodes etc), but i'm considering maybe building a new amp to try the vfets in... they are rank 58! Not giving up on the Sony, but I think a new design could do better.
I'm not a novice, but far from a expert. I probably need a design, with boards and some test points with voltages to check.
So what should I build?!
You should wait for part 3 which has circuits and pc boards to accommodate these
particular parts. The 2SJ18 ad 2SK60 are the single-die versions of the duals in
2SK82 and 2SJ28, and unless you are driving 16 ohm will need a mu follower instead
of a constant current source.
No big deal, and patience will be rewarded.
:snail:
