What ready made Chassies du you use for your FirstWatt amp?
I am planning a build on an M2x amp and Ive been checking on some chassies:
Dissipante 4U 400mm frontale 10mm NERO coperchi e retro in alluminio 3mm
4015 Full Aluminum amplifier Enclosure/AMP case/ Preamp box/ PSU chassis | eBay
WF1185 Aluminum Enclosure Class A HIFI Amplifier Chassis Preamp Case/Amp Big Box | eBay
WA129 Aluminum Power Amplifier Chassis Class A AMP Case DIY Luxury Shell Housing | eBay
What chassies are you using?
Links and pictures......
All and any Class A amplifier will need a lot of heatsink so any chassis should be chosen with that in mind.
Easy, the Modushop Dissipante you linked, much more heatsink area and made in Italy as well - not China. Perfect for your class A amp.
