Only true midbass cabs I am aware of are Martin 115 type design, they also have an S1 15" cab which looks like a folded horn design, what other cabs are there for effective 15" mid-bass please?
Thanks, I am being told that there are also 15" folded horn cabs but I am not finding any since they only seem to have 18" versions?
What is "mid-bass" to you?
Plenty of "kick bin" bandpass-horn cabs out there, depends how high you want to play
What freq are you looking to cover? What subs and tops are you mating these midbass cabs with?
Why not build some some simple bass reflex cabinets, which allow you to get a somewhat extended upper frequency response so you don't need huge tops....
I am using a sonic dual 18 bass reflex sub. I know this forum is about building your own sub but first I am hoping to get some names of some 15" midbass cabs so I can go looking to see if I can get a pre-built one, so far I have found EV TL4025 and Funktion-One DS15 [which is very expensive]but it's a start for me to go looking.
what was wrong with the hyperfold? other than its a 4x15 and weighs 250lbs... 😛
But if you are using a bass reflex cab, why do you need a midbass cab? why not just invest money into tops that can keep up down to 80 or so.
Nothing's wrong with the hyperfold, I am just accustomed to the type of bass which comes out of the two cabs I mentioned and that is I am seeking to get any other brand with the same design.
- Subwoofers
- What options are there for mid-bass?
