When you replace a 10MHz GBW opamp with a 55MHz one it would be prudent to check the decoupling and monitor the output with a 'scope to verify there isn't any oscillation. The 4562 has higher current noise than the 5532 so, depending on the surrounding resistors, might not be an upgrade in noise terms.
