What are people using for multichannel dacs when using active computer based crossovers?
I would like to play flac files stored on a hard drive through computer based active crossovers then out via usb to 6 channels of dac, then to my amps, then to my speakers.
The only multichannel dac I have found is the exa 8 channel product that only outputs single ended. I want to use my ncores with balanced inputs....
Any suggestions? The only thing I have found is the 8 channel buffalo 3....
You can get XMOS - USB Streamer - and output many I2S and choose the DACs.
USBStreamer | miniDSP
http://www.diyaudio.com/forums/digital-source/227437-es9023-dac-design-minidsp-usbstreamer.html
I have a exa21 usb to i2s board but am looking for a 6 or 8 channel dac with balanced output. I will have a look at your suggestion....would like to find a es9018 solution...Thanks.
