What makes the JBL 2226H such a popular driver?
JBL 2226H Measurements
I know this is an old thread but ...... I had a pair of JBL 2226H sitting around collecting dust and so I thought about recycling them into another project.
I took quick measurements and was pretty happy to see the results. Nice smooth mid-range with minimal cone break up. This is raw response, 1/24th smoothing, no EQ, no baffle step circuitry, etc
This measurement was taken outside, groundplane method technique, with the mic placed 6.5 feet from the baffle (18"w x 24" tall - approximately the dimensions of Wanye 4pi Speakers), and the baffle tilted down so the woofer is facing the mic.
These measurements matched remarkably well to the measurements I took indoors utilizing the technique suggested by Mr. Bagby (RIP)- LINK.
Just thought I post my results here if anyone found themselves reading this thread.
a) no power abuse (Im in a home setting) b) some maintenance routine?
Excessive excursion or power can cause rapid, even instantaneous mechanical or thermal failure (a).
B) Every 20-30 years the driver may need to be rotated to reverse cone sag, which can eventually lead to the voice coil or former rubbing in the gap.
If the drivers have been stored horizontally for long periods of time, the suspension may settle forward or back from optimum position, that offset could cause more harmonic distortion than if the voice coil were properly centered.
Surround glue may dry out and crack and require re-freshening at similar intervals, depending on environmental conditions.
That said, many pleated surround drivers around for over 80 years are still working just fine, and have still not reached their "half life".
