I have to admit, to confess, that i am feeling myself
bored with so many folks asking me what is the best
amplifier.
I do not know!…I am still searching for it.
No one knows, because this is subjective, individual…
there’s no two persons that feel alike, listen alike,
taste alike and so on.
People is always searching for privileged informations
about Aksa…. I will not tell you a single word…or…
will say something is public, and that means nothing,
or half of nothing.
What makes an amplifier good:
Correctly biased..all transistors operating into their
best points respecting it’s datasheet..voltages, currents,
and the most special…VBE
Electrolitic capacitors that are not inverted
No transistor too much hot, thermal noise
Not too much stages..each one distorts
A good supply, the one you can suck all the current
the amplifier needs into 2 ohms loads and no noise
will come from the supply…just that..put 8 hertz and
turn oscilator volume up…turn amplifier volume up
and no mains noise can be heard… have noise?..
increase filter capacitance..ready..now a good amplifier!
Wants sound stage… use two supplies..this is the best
way to have good separation, and as consequence sound
stage…or buy trick amplifiers, very well designed and
developed…the only one…Aksa 55….only this brand
produces special sound stage….and I have built and
listened more than 4K amplifiers..and this happens because
a trick used…not even dead I will tell you…. If you
think I told you..be sure I was fooling you.
ALL AMPLIFIERS ARE GOOD…ones less good when
too much complicated into the audio patch..not the
surrounding parts…. Say..too much stages…double
differential..special differential with too much transistors,
trick fets and so on…to be good they must ONLY be
working fine..say..voltages and levels not wrong..and
this is not hard to obtain…so… those complicators
of course will be frustrated..for sure they will.
The good amplifier, or the best…is the one you have,
the one you built..the one you select, the one you bougth,
because YOU is an important subject…EGO… selfpride
You can believe your amplifier is the best one…the same
way you think your wife is the most pretty woman..and she
is not..this is only pride and the natural need we have to fool
ourselves…also your son and daugther are not the most
clever ones…you feel this way because you want..this
makes you feel good..so..go dreaming!
If you believe special stripped capacitors sounds..them install
some into your amplifier…. The sound will not change..but you
will perceive something changed…you have made your mind…so
be happy with your illusion and buy more stripped capacitors.
What makes an amplifier special..some tricks…I know only one…
Aksa….. and I can make any wide world amplifier sounds alike…
i know the tricks..will not tell ya…
What makes an amplifier sound better than others…. The speaker does
that..your mind does that…power does that.
What makes an amplifier produce better sound stage…. Heheheheh.
What makes an amplifier punchy…. Big condensers into audio patch
and feedback line….bit condensers into the supply..and your mind you
have made it in advance.
Boys..now a days I am searching the no good ones…as the best one
i could not find..only the best one to sound stage….. nothing more
now I am having fun testing schematics…to discover the one is
real bad..and understanding what makes them bad.
What do you think makes an amplifier good, or special.
Post your ideas here… agreements and disagreements.
Boys..do not ask me what is better…. I do not know..ahahahha.
Mine amplifiers are better!!!..ahahahahahah!
Carlos
All amplifiers sounds reasonable, or nice, if not defective!
It is hard to find one that sounds really terrible (Evolution)
I am good cooking fellows... and having girl friends.... those things i know how to do better than average
amplifier.
or half of nothing.
Carlos
People uses to confuse things..because i love to assemble amplifiers and because i'm
very active into the forum, they think i know the misteries of life.
I do not know...and worse...i could not find someone to tell me what is the best amplifier...and prove that!
No one has answered me basic questions about life, death, and
how to understand women...no one knows.
If you know something about the best audio amplifiers (yours naturally!), tell us.
Post here!
regards,
Carlos
Post here!
regards,
Carlos
I'm not sure I agree to that it's subjective. I think the best amp is the one that adds or subtracts the least. If you add the amp to the signal path (with a "smart" dummy load) and can't hear any difference, it's perfect.
Yes... i agree...if the one perceive those details
and that's the main question...do we perceive?
regards,
Carlos
regards,
Carlos
Re: Yes... i agree...if the one perceive those details
Midlife amp crisis biting again?
All the good sounding amps sound different, not one is better over the other, in a synergistic system one will sound better/best over the others.
There is no pot of gold at the end of the rainbow. That is why I don't build many amps of the same kind eg solid state. I build only solid stae, tube and D-class, to me there more differences among these genres of amps.
Yes Titan..there are differences..but not so strong to allow you to decide the one is
the best.... maybe the better to yourself..subjective, personal.
regards,
Carlos
regards,
Carlos
define 'best'
best sounding, well what sounds best to you may not to someone else...
best engineered...may not be best sounding....
best measuring? which measurement?
I could go on and on....
Joined 2009
doesn't it depend also on the speaker ?
I mean, depending on the speaker the choice of amplifier may be different, even for the same listener.
And doesn't it also depend on the music. I remember auditioning a KRELL system once. I heard 'glare' on the violins and didn't like it. But had I been listening to heavy metal I may have been really impressed.
Joined 2009
Carlos,
Did you read "zen and the art of motorcycle maintenance" yet ?
[http://www.design.caltech.edu/erik/Misc/pirsig.html]
"And what is good, Carlos,
And what is not good...
Need we ask anyone to tell us these things?"
'best amplifier'
I believe the jl-hood 80w mosfet is one best(transparent) amps around. I know some will disagree but have you built it, with optimum earthing etc? As jlh said why publish another design unless you equal or exceed the current commecial offerings? that should be the goal,shouldn't it?
JLH amplifiers are great.
Come on boys...i would like to read points of views... and also what is the best.... how to detect the best.... do the best exist?...not to be making questions.... answer question boys!
Thank you to the ones have cooperated with point of views.
I cannot answer..i want to have feedback, opinions and answers...i cannot answer...as i said..i don't know.
Carlos
Carlos
Joined 2009
yes, there isn't an answer until you define best.
I think perhaps a way to hone in, is say
best at low thd
best at slew rate, and other transients...
best into low loads
etc...
most reliable?
best bang for buck..
you can't say best sounding, unless you get some team of all of us to listen to all amps and come to some consensus.
there is no best as you can't say one can do it all, engineering is a compromise, things do better at certain things than others, hence my take.
in the end, its best for you,
or perhaps, your favourite???
best at low thd
best into low loads
etc...
most reliable?
B.E.S.T..... Bom, estável, sonoridade, tolerável
Good, stable, sonically, tollerable is the meaning in english.
Observe that we have thousands that will fit this definition (if you need some)....and year after year more and more nem models and new brands appear.
Interesting topologies, new schematics are beeing produced..and almost all them sounding good.
Maybe all them are B.E.S.T.....hard is to find the ultimate.
Now a days i am trying to find the non good one.
I think, in my point of view, despite respecting different approaches and ideas about, that makes more sense to search for the non good one...as we have a lot of very good amplifiers around.
All them almost sounds the same..speaker makes the difference.
People use to E mail me and ask what is the best?
I do not know exactly...or...it seems all them are the best.
Now i have some kind of answer...will point them this thread link as i cannot answer them.
And about you.... do you can?
Carlos
You see..no one knows.... observe no one pointed the best one!... and we are the best source someone can have...world audiophiles together into the best wide world forum.... this one we know "that's the best!"
Carlos
Well..... a challenge to you folks.
Let's say the best is the one reproduces sound with superior fidelity.....or the one matches the reality.
I will propose a test:
You put a small Orchestra to play... and those folks are able to play the same music repeatedly without change a single musical note.... them make a digital recording...the best possible recording for our days..... them play it with the equipment you think it is the best one.....
It will be the best if you will not be consistent, blinded, to detect the one is recording playing and the one is alive reproduction... you know?..... if you vote into the amplifier, and them to the orchestra...and them to the amplifier... and they will play alternated... the speaker will be in front of the Orchestra.
Now you have a definition.... high fidelity.... defined!
regards,
Carlos
This is the problem, i cannot as i have never made this kind of serious test....and i would like to know if someone has made... this one may be able to tell us something.
regards,
Carlos
And there's another problem.
Let's suppose you find the one that matches the reality.
Was the amplifier?...or the speaker?
So you gonna need to fix the speaker and replace the amplifier.
This asks a nice research about...i just cannot do that..no Orchestra , no excelent speakers, no sound stage to do that and not enougth amplifiers.
So, it seems a serious testing was not made yet...or at least.... the one has made is not present in this thread.
Carlos
Carlos
You see... even different sittuation
There are people researching..doing comparisons, studying those things.
we use numbers only.... tests may help.
http://www.youtube.com/watch?v=-fntcjlcJuo
This is not our problem...this is another issue..but shows research, comparison and the presence, very clear, of differences.
regards,
Carlos
regards,
Carlos
Here you can see differences
Landry is clearly better.
http://www.youtube.com/watch?v=DCadQjkxMLY
But they are both good.
regards,
Carlos
regards,
Carlos
- What makes the best wide world amplifier..how to detect the one!
