What made this cap ' jettison'?;
Maybe it is a good idea to use the same capacitors as behind the fake caps. Then the value is the same as indicated in the schematic as well.
15 kuF (kilomicroFarad?!) or even worse "kuf" is nonsense lingo, just use 15,000 µF or 15 mF if you want to be eccentric 🙂
IF you want to build well performing so good audio that also lasts a normal lifetime then avoid Ebay to buy electronic parts.
