What kind of Soldering Iron for lamp terminals??
Hi Folks,,, I have a standard Unger 45 watt Iron and it doesn't even put a dent in the solder that is used to hold the wire and the terminal on the philips UHP lamp. I want to unsolder the center wire and use a solder sucker to make sure its clean before wrapping the new lamp. the teminal looks like it has a little collar that is crimped on the wire and then it is soldered. Is there any particuluar Iron I need to use or how have others done this in the past??
Many Thanks in advance,
Bohanna 😱
