I use 28 ga solid core silver wire and teflon spaghetti tube. It's reasonably priced and not that difficult to thread the wire through the tube. As long as you don't need long runs of it. And if it's in a hook up application, it should be short anyway.😉
Joined 2002
spock said:I use 28 ga solid core silver wire and teflon spaghetti tube. It's reasonably priced and not that difficult to thread the wire through the tube. As long as you don't need long runs of it. And if it's in a hook up application, it should be short anyway.😉
I use this in one of my product's too. I also have some 3 way sheilded stuff that i use. Now-a days the expencive part is labour time and the actuall rca connector's.
maxlorenz said:Olive oil, he, he 😀 😀 😀
I think I'll pass. I don't like how it smells![]()
Ciao, mio caro...
M
PS: maybe human oil 😉 , or better... honey!
Honey lasts for ever.
It is said honey in good state was found inside egiptian pyramids.
No one dared to taste it, though 😀
..."smells"??? Ae you kidding mio caro?
Nope, olive oil made with olives from liguria do scent
... I guess that honey would get a bit dusty and, so to say, somewhat sticky...!
Stefano
Can someone describe 'silver ribbon' or link to a pic?
I did a google but got loads of PC type ribbon cable or 'silver wire' links.
I have a Dac kit connected to a CD-ROM with a cheap RCA cable, any suggestions on how to link the CD-ROM digital output (2 pins) to the input of my Dac (also 2 pins on the PCB); the distance is < 10 cm.
Thank you.
Thank you.
This thread shouldn't even be in this section of the forum as it really doesn't relate to digital applications at all. This is just another rehash of the same 'my cables sound better than yours' debate.
Could this get moved?
ble0t,
My original question was mainly to find out what type of wire to use inside a DAC or CDP to carry digital signal. So I'm not sure why you think it doesn't belong here. It's like TV programs - if you don't like it, don't watch it.
here's solid core silver wire on sale - just check if it's been heat - treated first:
http://cgi.ebay.com.au/Pure-99-99-s...9713196403QQcategoryZ3280QQrdZ1QQcmdZViewItem
Extreme_Boky
Extreme_Boky
johnthedoctor said:Can someone describe 'silver ribbon' or link to a pic?
Not very practical for internal duties in its flat state.
http://www.realhi-fi.com/products/sonic.html
http://earthshakingmusic.com/VSF6.html
That's very good speaker wire – but it's “only” an alloy.
I was referring to pure silver (6N) ribbons heat - treated. They can be cut even narrower, or wider, or used in parallel – 2 ribbons of different width (combination I prefer!) This is a sample of low signal hook-up ribbon I use in all my modifications:
Extreme_Boky
Extreme_Boky
MGH said:ble0t,
coax, and either soldered connections or bnc connectors. you can use sma connectors if bnc is too big for your application.
bb
Joined 2002
rfbrw said:
WAY! over priced.!
- Digital Source
- What kind of signal wire do you use in your DIY DAC or CDP?
