What kind of old type of capacitor are these?
I don't recall them going bad, certainly not on a broad scale.
Hugo
That's true - I barely found them to be defective.
You might paint them a more pleasant colour - that'll going to have a strong confirmation bias effect 😉
I suspect they work fine.
I think that some of them were Pale Green, and others Brown-Orange, in the same era, but I don't know who produced them, though... Possibly Italian too : Ducati ? Mial ? Under license ?
T
I have several cartons of Russian PIO caps that are glass sealed. They are all in sealed cartons brand new. Would these caps be good for coupling capacitors in pre-amps and tube amps. Would they also be good as bypass caps for electrolytics?
Any comments and suggestions would be greatly appreciated. thanks in advance.
Yes - the Astrons are very sought after for Fender amps. Counterfeiting and faking has hit the bumblebee market.
Even if one discounts the perceived differences in sound with these vintage caps, the vintage collectors want to see original style caps in the amps.
Reactions: Capman1961
Being in the capacitor industry for 43 years this May (2024), not a lot has changed in the technology. Bumblebee caps were polyester with aluminum and/or tin foil with a particular impregnant. Some films have gone away, such as Polycarbonate, Polysulfone, Polystyrene (for the most part) and thin PTFE. There have been minor changes in materials and/or technology for metalized films, but for the most part has remained the same. That said, technology has allowed for the manufacture of thinner films, particularly polypropylene.
Reactions: Pano and gorgon53
I disagree, Mil-C-19978 Characteristic P from 0 C (correction from -50 C) to 65 C is flat, 150ppm, +/- 50 ppm. I've been in this industry for 43 years, worked as a capacitor design engineer for 4 different companies, one was the leading US Military supplier for many many years. I also working in the materials industry for film extrusion and metalizers. I can tell you if the PS is annealed and stress relieved, its virtually flat TC. Honestly it doesn't matter, as they are not commercially available......
Reactions: JMFahey and Pano
Capman, would you happen to know the foil thicknesses/voltage relations for the different dieelctric materials?
In film/foil (or metalized) that is a complicated subject. Each dielectric has different withstands, with metalized being complete different. Actual application and life expectance play an important part of that. Often multi-layers of thinner materials are put together, say 4 x 6um will withstand more than 1 x 24um. Temperature also comes into play. As a rule of thumb, 300 - 600V/um while considering the parameters I listed above.
