What is wrong with this driver?
Its a pair of Seas FA22
H1597-08 FA22RCZ
One of them has a significant dropp in frequency in the upper range.
The measure equal re (Ohm) and le (with a LCR-measurement)
Please look in the link to the forum thread under:
The first measurements is in the cabinet with correction filter (baffle step & notch)
The latter is measured outside the cabinett close to the driver without any component
Noen som vet hvorfor? | Hifisentralen
Note: whizzers are primarily a [high] mids BW device to enhance/project vocals, so normally no place to be looking for actual HF [> ~ 6 kHz] anomalies.
The voice coil [Vc] dia. limits point source output to ~34400/pi/2.6 = 4211 Hz, making the whizzer BW going back down to ~600 Hz, ergo something's weird with the dust cap's [dc] output, so apparently something different WRT density and/or stiffness and/or whizzer, dc, Vc connection. Note there could be some HF coming off the diaphragm also, comb filtering with the dc's output.
FWIW, IME and lacking any experience with using a mic to look for such 'needles in a haystack', a mechanic's stethoscope has been my 'best friend'/most used test tool. 😉
Interesting behaviour.
I'd do the following checks:
- Swap speaker cables between one speaker and another - make sure it's not an amplifier or something else acting weird
- Make sure the mic position is perfect each time.
After that, I'd contact Seas and see what they say.
Chris
I have done that. Double checked!
And also contacted Seas. They are btw located 15 min from my place. I have visited them before 🙂
But they didnt know whats wrong. Maybe someone at R&D should look at the measurements they said.
One guy had an idea that it could be something mechanical. F ex that the magnet got a punch (but i cant see any marks) and then the voicecoil is very little misplaced in the gap? I dont know?
