What is what on an EI Transformer
As some of you will have gathered, I'm very new to the world of electrics. I'm about to start putting together a LM3875 kit from Peter at Audiosector (very nice looking kit), and I want to se if I can use an old EI transformer from an old faulty Marantz PM66SE amp.
Trouble is it's been seperated from the Amp and I don't have a clue what I'm looking at. Can anyone tell me which connections are what.
Thanks again for any help you can offer a newbie.
I promise to put any info on my website so other newbies in my position can hopefully be referred there...
The thinnest wire and coil with highest resistance is the primary. Looks like the terminals on the right. There may be two primaries which get connected in series/parallel depending upon the primary voltage (220/110).
If you want to be extra careful feed the assumed primary with very low voltage (12v?) and see if the secondaries get the expected lower voltages.
Thanks for the help Analogue SA. I'm going to do what you said.
In the meantime I've done a search of this website and found a reference to the pm66se transformer which says the secondaries are 28.7 v AC which gives 38.4 V after rectification.
IS this accptible? It seems higher than what is usually recommended on here. Is there anything I can do to make it work?
Thanks Nordic. I was a bit concerned because the consensus seems to be "transformers with 18-22V secondaries are well within reason for many common commercial and DIY speakers. A transformer with 25V transformer secondaries can also be successfully with less of a safety factor."
Is overheating of the chips the only thing I need to worry about?
I'll take out the two large heatsinks from the same amplifier and use those.
Will this affect sound quality and/or reliability? I read somewhere (can't remember where now) that a lot of people like to run Gainclones with low voltage for better sound (albeit quieter).
In the long term I have started to consider bridging or running two or more chips in parallel (saw this post on [url]www.gainclone.com[/URL] and thought I'd wait and see what the more experienced contributors thought. Bridging appears to produce a less defined sound, but I haven't found any reviews of parallel circuits.
Could I power both from the same transformer and would this mitigate the high voltage problem?
You also don't want to drive 4 ohms with that, so watch the impedance.
If it heats up enough, Spike will kick in, and yes its audiable...
I'm not qualitfied enough to be able to judge the validity of the following statement but I do believe it to be true.
As you drop the supply voltage, you increase crossover distortion.
It is all about which compromises you are willing to take.
Thanks Nordic.
Jees. I can't see the reference in the pdf from Nat Semi. When you say "the LM3875 will handle 4 to 6A (varying from chip to chip)" is that the maximum?
As I've said before I'm new to all this.
If I use one rectifier bridge:
38.4 Volts output from the transformer/ 8ohms rating of my speakers = ~5 Amps current. This obviously falls right in the middle of the range. So I guess it's important I find out whether that rating range is a variable maximum (which varies from chip to chip) in which case I could be in trouble or whether that's a prefered range, within which the chip operates fine...
