What is this component?
Hi
Long time lurker first time poster!
I have a spinning speaker from a Yamaha organ which I am trying to get working. The speaker works fine it’s the motor that doesn’t spin. It turns but at about 5rpm, should be running at over 1000rpm I suspect.
I have found a burnt out component but don’t recognise what it is and searching google doesn’t bring anything up. Best I can guess is that it’s some sort of diode? It says IR2C with a blue band around it. There’s five of them and one has gone black. It’s the obvious fault at this point before I go changing anything else.
Does anyone know what this part is please so I can set about replacement? The first photo shows the part I’m on about and the second photo shows the particular part burnt out.
I would really like to get it working so would very much appreciate any input.
If it helps it’s from the early 1970s I believe.
Cheers!
I believe 5rpm is probably correct. The church I grew up in got a new better organ for the sanctuary and the bass units spun at a very slow rate. I think they were mimicking something real pipes have. It also had a "chiff" option, which added a little puff sound at the beginning of higher frequency notes. That I know is a real effect pipes have from when the air first starts coming out of the pipe.
Since it's 50 years old, be sure to check out the mechanical parts too.
It's common for a mechanical overload to cause an electronic failure.
Look for bad bearings, bushings, gears etc, anything that can bind up and overload the motor.
