Apparently the speed of light is not constant:-
Scientists slow the speed of light - BBC News
Alternatively, it's no longer a photon (I.e. Light) after it's been through the screen (see the article for details)
Either the explanation is flawed (more likely) or the experiment is flawed.
If one photon is delayed IN the mask, and returned to normal speed after exiting, it would arrive at the target delayed by effect of the mask slowing it down during it's transition through the mask.
It would be necessary to measure both photons at two points of equal distance after the mask to determine if both were going the same speed. The photon which went through the mask would arrive at the first test point behind the non-masked photon. It would arrive at the second test point with a different and greater delay than when it arrived at the first test point in order to confirm that it were still going slower.
This is not what was described in the article.
I've seen a setup using prisms and a slightly longer path delay for one of the light beams to generate interference patterns arising out of the delay between the two beams. This is old hat.
I would be amazed if the experimenters had made the error you are suggesting.
We shall have to wait ans see what the response is.
Indeed... the thread has slowed down too...Apparently the speed of light is not constant:-
Albert Einstein: Still considered one of the greatest thinkers and scientists in world history, Albert Einstein had a troubling school life. While he was successful in his early education, Einstein was expelled from high school for being rebellious, and was not accepted into Zurich's Federal Institute of Technology on his first try, and failed the entrance exam. After getting his high school diploma at a different school, Einstein returned to FIT and was admitted.
10 Famous People Who Were Expelled From School
I am still in deep thought..😀
A while ago I watched this..(be it correct or not its interesting)
https://www.youtube.com/watch?v=8BTcmuGdLCU
I am leaning towards these kind of ideas..everything could just be waves..in what? is the next question..🙂
OK we already know everything is probably just energy..
Could the universe just be an interference pattern? It seems to explain the double slit experiment quite well..
Ie if the input particle is actually a wave not a one point particle it will go though both slits at the same time and interfere with itself..
A strange question..predict your next thought..or what will be your next thought...this is difficult to understand. Until you think about it! (what am I going to think next?)<<self prediction.
NB even if its an interference pattern where is the pattern happening?
M. Gregg
M. Gregg
Perhaps a photon is a packet of probabilities, wrapped in 'strings'...when an encounter happens, the probabilities are released. I'll have to think some more about this...
______________________________________________________Rick....
🙂..yes it raises many questions..
For those that cannot get Youtube here is the idea on Daily motion..
http://playdailymotion.com/watch/CkEmzuHT_CY
http://playdailymotion.com/watch/zW7hBRsrGoI
M. Gregg
An expanding universe doesn't need to expand into anything when it is its own space that is expanding
I think a likely possibility is that they have inadvertently increased the length of space, that's not a constant
Its all quite strange..😕
A few stupid thoughts...
If the universe is an interference pattern or some kind of hologram where could the source be..😀
It still poses the question..even if its infinite where is the infinity.
More stupid thoughts...if something entered the "source" of the reflection would it just appear..a bit like the flat landers and the 3rd dimension.
(oh look another particle has just appeared).
I guess we have no control over the process....hummm..
The question..what is reality?<<it would seem there might be an answer the question might not exist!😀..
And I haven't been drinking..🙂..It sounds like some kind of surreal madness. or perhaps just spooky.
I can accept a universe that is waves or an interference pattern or hologram..however it leaves a strange feeling about reality.
It makes me think about the Buddhist monk that told me everything is nothing and nothing is everything.
Reality or truth would seem to be beyond life..(could life be an illusion?)
Back to the universe...
M. Gregg
M. Gregg
The same might apply to the universe, which could be an expanding illusion too..😀Reality or truth would seem to be beyond life..(could life be an illusion?)
😀..I must admit that I tried just thinking about this and it has an effect (not very pleasant)..so I have to sort of allow a realisation to take place..
The problem then is I have to stop for a while..have a few beers and step back to this world..😀
I get the impression you can't just think about this a realisation has to take place..let the dust settle and reappraise.
I have found this before with another subject..what does it mean to comprehend something..(limited by illusion)..😀
M. Gregg
I found my thought also quite disturbing....😀..I must admit that I tried just thinking about this and it has an effect (not very pleasant)..so I have to sort of allow a realisation to take place..
I experienced no problem with that this afternoon. Had several beers, played some pool and had a good chat with a valued (girl-)friend of mine...The problem then is I have to stop for a while..have a few beers and step back to this world..😀
perhaps the universe seems to be expanding because we're shrinking...I get the impression you can't just think about this a realisation has to take place..let the dust settle and reappraise.
M. Gregg
I see your point...NB not the video..😀
So I guess you are not in agreement with post 1368#..🙂
M. Gregg
For interest,
I like the cosmic history picture, its a bit different from the usual one.
The Universe's First Stars Flickered On Much Later Than We Thought
M. Gregg
M. Gregg
M. Gregg
Nota Bene?
sufficiently vague, not sure what you mean.
i have yet to watch both videos in post 1368.
- Member Areas
- The Lounge
- What is the Universe expanding into..
