Well, "everywhere" was the size of a ping-pong ball so it's not like you would get lost there 🙂
I wonder what "everywhere" expanded into? :-DDD
One possible way to think about the why the universe is expanding is to consider time and energy as being two sides of the same coin. Energy can only be converted from one form to another, through time. Stated differently, time can only pass if there is a change in energy - either through expenditure or a gain.
To illustrate this, consider two bodies falling freely through space and in close proximity. Both will experience the passage of time at the same rate. If we then apply a force to one of the bodies, we expend energy to do so and we set that body off on an altered trajectory and the distance between the bodies increases. We can see distance therefore as a proxy for time: you cannot have a difference in time without there being some expenditure of energy - ie you trade one for the other.
So, in the visible universe, we have a huge amount of energy, that under the laws of entropy, is moving towards a net uniform state ultimately across the entire universe - the cold dark hypothesis. This process can only happen through the mechanism of time and in fact ‘drives’ time which is manifest as distance between objects hence we see it as an expanding universe.
Really? A mistake? What Kind of mistake? Care to elaborate?Yes, but that was a mistake that he always regretted.
We can only see as far as nature allows us.Skipping past the "near universe", such as our galaxy, and go out to seriously deep space - other galaxies, where does it end? Does it end?
Light from galaxies in the universe beyond our observable universe has not yet had time to reach us, and its journey time is made even longer by the expansion of space.
There's more of the same beyond our observable universe, we simply can't see it and no one knows how far it stretches. Well, that's one hypothesis anyway. 😉
Are there observable examples of entropy at it's conclusion?One possible way to think about the why the universe is expanding is to consider time and energy as being two sides of the same coin. Energy can only be converted from one form to another, through time. Stated differently, time can only pass if there is a change in energy - either through expenditure or a gain.
we'll never knowIn a space where the temperature is zero (0) Kelvin, time stands still.
No it does not. Time will only stand still when there is zero energy change.
(Read about it recently).
But if entropy has taken the entire Universe to absolute zero, there will no longer be a change, no?
The confusion arises because the observable portion of the universe was once packed into an incredibly tiny volume. All of space was filled with energy at the Big Bang, but the volume of space that could be observed was tiny. The volume of observable space then expanded, but there was no centre to the expansion.... the contention is that the BB happened "everywhere" all at once, not from a singularity. This is what I have been questioning.
TNT, electrons will still have spin and the atomic fundamentals will still be in place. The cold dark universe means the average energy across the entire universe is the same and at or very close to AZ.
Not sure I follow Galu. Probably due to the, for me, vague definition of; universe, space, observeable space.. sorry Galu! 🙂
"then expanded" affirms a singularity?The confusion arises because the observable portion of the universe was once packed into an incredibly tiny volume. All of space was filled with energy at the Big Bang, but the volume of space that could be observed was tiny. The volume of observable space then expanded, but there was no centre to the expansion.
can the mass of matter before the BB be calculated as to how large it was?
We have no accepted theory for that, although there is speculation. Such a mass could be extremely small,
or even just a random quantum fluctuation. The only well accepted theory begins after inflation is over,
and can't accurately model the universe before that point.
One interesting approach is to consider deep time, and the identity of the far future and the far past, both being
a universal vacuum. There may be a very smooth (and very slow) transition from the future to the past, which
would then form a new universe, without any special initial conditions, or big bang, needed.
There are still quantum effects.
So what adjustments were made to accommodate inflation? Or was inflation needed to accommodate expansion?
A single theory could not be devised without needing inflation at a certain point. Inflation was invented
as a "patch" between theories of pre-inflation and theories of post-inflation. Many theorists are not happy
with this situation, though it works if you accept that inflation actually happened. There have been several
versions of inflation (to correct early problems with it), such as getting inflation to stop at some point.
Since it was the observable universe to which I was referring, let me supply this definition in the hope that it may help. 🙂... vague definition of; universe, space, observeable space..
The observable universe is a spherical volume centered on the observer, regardless of the shape of the universe as a whole. Every place in the universe has its own observable universe, which may or may not overlap with the one centered on Earth.
- Member Areas
- The Lounge
- What is the Universe expanding into..
