Here some more waffle to ad to the rabble
I'm not sure I fully understand…
Some people seem to be of the view that if you hear a difference between valve vs. S.S amp you imagined it or if it wasn't a double blind test, you imagined it?
Once I upgraded my amp from a 60 watter S.S to a 200 watter S.S - there was a big difference in sound: for example through the 60 watt amp the bass was 'relatively' vague, nondescript. Through the 200 watt amp, the bandwidth seemed to increase and I could now identify that the bass player (of a album/track that I was a favourite at the time) was playing with a 'swing' feel. The general fidelity of 200 watter was on a whole other level.
Another example: I've spent occasions (a couple/few of hours) listening to 'Gillian Welch – Revelator' album, on a valve system, then coming home, and straight away listening to same album on my S.S system – the differences were'nt subtle. And not a factor of the room, the speakers etc.. Amps are critical to the signal chain, they're not sonically benign or not transparent/invisible.
Is it reasonable to say that there are sonic characteristics or properties typical of valve amps and typical of S.S amps? IMO there is, although there can be exceptions. The fidelity, sound, music you hear, is from a result of the interactions between the amp and the SPEAKERS, and the room. IMO valve amps seem to interact with speakers (and cables for that matter) 'relatively' more than S.S amps do. They're 'spongier' or under damped, relative to solid state. Some might say that S.S amps are overdamped. Then there is the distortion profile or lack of a measurable distortion, or no distortion profile. Whether this is good/bad is a matter of opinion/taste/ones own philosophy.
But the idea that I can't, I don't or I imagine hearing a difference or that amps don't, in real world reality have a characteristic sound of their own, is absurd, overly theorised nonsense IMO.
If amps with different circuit topologies: SET, PP or Class A, A/B whatever, sound a bit different/interact differently with any given pair of speakers, I don't see why 'tube sound' could be such a contentious issue?
IMO: there is a general 'tube sound', I'm satisfied I have a pretty good idea of 'tube sound'. Having said that, it's not to say there aren't exceptions, or designs where a tube amp can have characteristics, we might normally associate with S.S amps. BUT I purpose that in matching some of those S.S characteristics, some other characteristic will be compromised. For example: you can't have a melodious midrange/treble like honey, as per amp A, and bass grip like granite as per amp B - in the one amp, in achieving A you forfeited B. A is achieved by amp being under damped, B is achieved by amp being over damped, but you might find a middle compromise.
I have seen multiple articles here and elsewhere about the "tube sound."
Some of the theories range from being the 2nd order harmonics to some complex, undefinable distortion given by the Gestalt of the entire amplifier (power, preamp, tube finals, output transformer, etc.)
I have found many mathematical analyses of tubes and distortion effects of a single tube but has anyone narrowed the "tube sound" down to a mathematical model?***
SY nailed it early on. It's mostly FR errors due to high source impedance. That's why older Class D amps (e.g. the old Panasonic receivers that were an audiophile fetish for a while a decade or so ago) and solid state amps with resistors on the outputs (e.g. Sunfire) are often described as "tubey."
Stereophile's tests of tube amps into their simulated load show the FR differences clearly (into that load at least).
Occam's Razor suggests that looking for smaller differentiators is silly, when a big differentiator (FR errors that vary with the driven loudspeakers' impedance) is well known.
Tubes have no sound.
Sure they do. Especially if you tap them lightly with a spoon! 🙂
The answer is - that an amplifier should be accurate. Trouble is, most aren't, in one way or another
That's one of those comments that's simply not based in actual reality.
IMO the midrange in valve amp is NEVER bettered/matched by the midrange in a S.S amp.
That kind of statement is consistent with FR errors (often elevated midrange) due to high source impedance in tubes.
Is it a akin to saying that Lionel Messi, Derek Jeter and Inbee Park are human and subject to the same problems and mistakes as anyone else, therefore they can't be trusted more than anyone else in Football, Basketball or Golf? Because they do make mistakes, their skills are an illusion?
Problem is, most "audiophiles" think they're RG3 with invincible knees, when they're really more like Ryan Leaf's third string high school backup...
Boxes of gain have electrical inputs and electrical outputs. Those signals can be compared by instrument, by ear, or by any other means you can think of (e.g., comparison to a reference).
Yes, but my point is that that you should be "distinguishing" input from output in the SAME medium. If you are listening to the output in a DBT, then to distinguish it from the input within the same medium (which seems the whole point to me) you have to listen to the live instruments that create the input. And at the same volume. The electrical input to the amplifier is no use as a listening experience because it's at a fraction of the volume.
Hi all. my day job is the lead designer of ct scanners front end electrnoics...and my previous job was at MIT as the lead diagnostics engineer for the lab of nuclear science. My hobby is instrumentation, music, and tube hifi. i wrote my MSEE masters thesis on amplifier distortion. It a fun read....some of it is tongue in cheek. http://www.dancheever.com/main/cheever_thesis_final.pdf
what i have learned since then ....building at least another 40 amplifiers...seems obvious...that when i build an amp to sounds good with ZERO feedback, and i apply a little feedback to control the output impedence...this amp will sound MUCH better WAY BEFORE clipping than a ultra high gain amp thats sounds horrible open loop.
its non newtonian in the sense that both amps at, say 1watt, show clean output on a fft...no high order harmonics. but thats with a fixed sine and the fft needs 1000's of cycles to make a picture. So maybe with broad frequency dynamic signals "stuff" interacts in the feedback...stuff that one cant instrument and catch in real time.
Hi Daniel,
Indeed a very good read. I totaly agree with your aproach.
Did you make a PC software to measure TAD available to public?
Best regards,
Radu
If that's even true, then what about RIAA, NAB/EBU, premphasis, Dolby processing, etc? Those signals would sound very corrupted if played back without correction.Once you've corrupted the signal, you can't uncorrupt it
That's what you say, but most audiophiles I know are rather humble and tend to underestimate their abilities. Don't be blinded by Internet boasting, in person very few audiophiles are like that. They do make mistakes, but I don't know any who think they are infallible or invincible.Problem is, most "audiophiles" think they're RG3 with invincible knees, when they're really more like Ryan Leaf's third string high school backup...
If your reality is purely based on the typical measurements taken that may be true. However, if you listen to amplifiers actually functioning as intended, and under different levels of "stress", then the reality is very different ...That's one of those comments that's simply not based in actual reality.
You might as well say that all cars that have similar acceleration figures will feel the same to drive ...
Anyone who thinks that, for instance, they can walk into a room at a show and "hear" the effect of amp or the wires or whatever...that's the kind of idiocy to which I prefer. That's the "think they're RG3, actually more like the 3d string high school QB" effect in action.
Likewise, a discussion of "tube sound" that barely mentions source impedance is just a circle jerk.
Sorry, but no, it's not. Try some real speakers (preferably not part of an Aldi TV) and get back to us.
Thanks! That's a fairly common type of retort from "audiophiles." The problem with that kind of half-baked analogy is, taking an electrical signal and making it bigger (which is all an amp should do) is a one-dimensional thing. (The important things in an audio system all happen elsewhere. The amp just does one job.) The feel of an automobile is a multidimensional thing. (Never mind that acceleration has very little to do with feel of a car, unless it's just a crude engine box like an old Detroit drag racer. Spring rates, camber, shift action, etc. are all far more important to feel in an automobile.)
The automotive acceleration analogy to amplifiers that makes actual sense is to say that all cars with similar acceleration figures will get from 0 to x in roughly the same amount of time.
One could say, perhaps, that most tube amps are like a car with a stick shift and no traction control. That is to say, its acceleration varies quite a bit based on who's "upstream." By contract, a solid state amp is like a modern with a slushbox or automated manual and computer-based "launch control" that basically takes the driver out the equation so long as s/he mashes the go pedal down. Even though I hate that analogy, because my strong preference in cars is three pedals and no electronic nannies.
Interesting that all amplifiers are the 'same', but all speakers are 'very different' ... 😉. Well, I have listened to hundreds of "real" speakers over the years, and on the basis of what they sounded like at that moment and on the 'assumption' that all the SQ issues I could hear are solely due to the speakers misbehaving, then for the vast majority I would be happy to biff them into the rubbish bin by the back door ... 🙂Sorry, but no, it's not. Try some real speakers (preferably not part of an Aldi TV) and get back to us.
And, the behaviour of an amplifier is a multi-dimensional thing ... which is the 'subtle' point I was trying to make ... 🙂Thanks! That's a fairly common type of retort from "audiophiles." The problem with that kind of half-baked analogy is, taking an electrical signal and making it bigger (which is all an amp should do) is a one-dimensional thing. The feel of an automobile is a multidimensional thing.
Having spent years very significantly altering the behaviour of amplifiers by modifying the environment in which the nominal amplifying circuitry operates, internally and externally, the statement that an amplifier is a generic black box of standardised and well behaved functionality is quite laughable ...
Sure, you can cherry pick whatever stories you like to make a point.Anyone who thinks that, for instance, they can walk into a room at a show and "hear" the effect of amp or the wires or whatever...that's the kind of idiocy to which I prefer.
Here's an audiophile story you'll love, you can add it to your collection. 🙂
A few years back I was at the RMAF show in Denver. Was walking down the hall and heard music coming out of a room ahead. The sound immediately struck me as familiar, so I stopped to listen and to get an idea of what was so familiar about it. I knew that sound - Tripath amps. Sure enough, it was the Red Wine Audio room. It was the first time I'd met Vinnie and heard his amps, but I knew the Tripath sound from down the hall. Now at the time I was spending many hours per day building and tweaking Tripath amps. I doubt I could do that ever again.
Of course some will say I simply recognized the sound of a familiar effects box. 😀
this is an ideal
In my experience valve amps generally 'feel' & 'sound' different to S.S amps
I don't get how by articulating the cause WHY, a characteristic is void
Audiophile story: I was listening to PP mono blocks with EL34's - and at it reminded me 'sonically' of an old Marshall stack.
No, it's not. Former has to exist, the latter doesn't.What they heard and what they think they heard is the one and the same
To whom and for what occasion? And how do you know?- it's the end message inside the brain that counts.
No, what you perceive can change by focusing on different aspect of the same reproduced sound.It's been mentioned many times that what you "hear" can change radically merely by changing one's inner focus -
Which expert's finding are you reciting? Or are you just expressing your personal opinion?as a parallel example, if looking at a 'beautiful' girl, and then deliberately noticing and obsessing on every slight "defect" in her appearance, she will end up appearing quite repulsive to you ...!
Did you mean "what do I do"? Because you are talking about what satisfies you. By the way, what do you mean "how 'natural' sound comes across"?So, what to do about reproduced audio then? Well, I've found that making the quality match how 'natural' sound comes across works best for satisfying my "inner hearing" ...
What sound difference have you heard from different amps that couldn't be measured?No, the type. Think wrapping a towel around your ears vs. dragging a nail across a saucepan ...
That's what you say and that's called anecdotal evidence. Have you taken a poll among audiophiles in larger demographics than your own circle?but most audiophiles I know are rather humble and tend to underestimate their abilities.
But he was describing the audiophiles on internet, was he not?Don't be blinded by Internet boasting, in person very few audiophiles are like that.
Yes, it's all about the amplifiers having 'signature' distortions, no matter what the measurements say - the 'ideal' amplifier will sound like ... nothing at all ...
A process I have followed over the years is that a system put together on the spur of the moment will have a certain quality, 'sound' to it. All recordings you're familiar with will be tainted by that 'sound' -- then gradually as the system is refined that 'sound' starts to fade, falls away - and the actual recording 'sound', the 'feel' of each album emerges as a distinct, familiar, "object" - an old friend is back!!
Completely different playback chains, and close to identical subjective impressions of the music played. That to me says I'm on the right path ...
Specifically an early 70's 100 watt super lead, non master volume. A colleague had lent it to me in the prospect I might buy it from them. I didn't, but in hindsight, I should've maaaan 😎
I didn't expect to see a forum moderator play spin. 🙄Again, I have no idea what you are talking about. 😕
It seems we are not. But I've read the page you're on. I'm further along in the book, now. 😉
You've stated,
so I asked,High Fidelity to the signal that was decoded by the player. That's not a bad choice, it's a great starting point, but it isn't necessarily my choice. It used to be until I found that strict adherence to the signal does not always result in sonic realism (for me).
Therefore my definition of High Fidelity is fidelity to the original sound, not always to the original signal.
and you've been spinning it ever since.Except for the loudspeakers, what other ways do electronic audio components work besides sending electronic signals?![]()
They don't just send signals, they can alter them. Most are meant to alter the signal. You don't want the signal straight from your phono cart or CD laser pickup sent unaltered to your speakers, do you?
Either that makes no sense at all, or I have no idea what you are talking about.
I don't know which amps you are asking about. Got any names or makes? Maybe I've heard them.
The reason for all this arcane discussion is to counter the SS fanboy argument that tubes do so many things badly, they can't possibly be accurate, thus never Hi-Fi. A lot of the things that tubes can do wrong, just don't matter to the final perception of the sound.
Pano, if you have experiences with comparing the fidelity levels of amps including tube amp, please share. I would like to read about it.
I'll try not to get into a tit for tat .... 🙂No, it's not. Former has to exist, the latter doesn't.
I was making the point that the only thing that counts, for us as listeners, is what registers in one's consciousness, at a particular moment. What measuring gear says is irrelevant to that experience.
That's exactly what I was saying ...No, what you perceive can change by focusing on different aspect of the same reproduced sound.
Could mention the experiments where beautifully cooked food is served under vile lighting, and people find the flavours disgusting - perception is very fluid, depends on 'everything' ...Which expert's finding are you reciting? Or are you just expressing your personal opinion?
Asking a rhetorical question. And, taking every opportunity to experience what normal acoustic instruments sound like in the flesh, sidling up to a couple of feet away from one being played - that becomes a reference "tonality" to chase after ...Did you mean "what do I do"? Because you are talking about what satisfies you. By the way, what do you mean "how 'natural' sound comes across"?
Every sound difference can theoretically be measured, but as I said earlier the testing methodologies are still too clumsy, unrefined. One of the better attempts, DiffMaker, can be fooled very easily, and is far too fragile and awkward to use seriously ...
this is an ideal
There are some reasons that one might almost call "trivial reasons" for why a tube amplifier may sound different from an SS amplifier. Namely, the higher output impedance, and deviations from flatness of the frequency response.
The claim has been made, and seemingly has not been refuted in any genuine double-blind listening tests, that an SS amplifier can be made to sound indistinguishable from a tube amplifier by adding a resistor in series with the output and an R/C network to appropriately "unflatten" the FR.
If it is indeed the case that there is nothing more to the "tube sound" than this, then it surely is important and worthwhile to know it? (Uncomfortable though it might be for those who wish to believe otherwise.)
Chris
Yes, listeners, as you said. Not as internet forum posters who want to talk about sound difference between amps.I'll try not to get into a tit for tat .... 🙂
Now you changed it from "if looking at a 'beautiful' girl, and then deliberately noticing and obsessing on every slight "defect" in her appearance, she will end up appearing quite repulsive to you ...! " Why? Couldn't confirmed the validity of your own theory?Could mention the experiments where beautifully cooked food is served under vile lighting, and people find the flavours disgusting - perception is very fluid, depends on 'everything' ...
Seriously? You sound like someone who knows nothing about acoustics.And, taking every opportunity to experience what normal acoustic instruments sound like in the flesh, sidling up to a couple of feet away from one being played - that becomes a reference "tonality" to chase after ...
Is that what you said? 🙄Every sound difference can theoretically be measured, but as I said earlier the testing methodologies are still too clumsy, unrefined.
One way of looking at it is that every audio system distorts, for a variety of reasons. Period. And, some types of distortion are easy to "hear past", they don't interfere with the mind's ability, in a stress-free way, to filter out what the musical message is in what you're hearing. Systems that produce more of the "nice" and less of the "irritating" distortion will always be subjectively preferable - but the measurement techniques are too simplistic, too primitive to separate the types ...
fas42, you've got multiple problems communicating with others. It is now clear that trying to do that with you is a waste of time. Good bye.
- Member Areas
- The Lounge
- What is the "Tube Sound"?
