I haven't found anything precise about this
what is defining if an amp is class A?
are there some equations, ore other requirements?
thanks
thanks
ok
but does any relation exist between Vcc and Vds, Vcc and Vg...?
I don't clearly understant "conduct for the full 360°"
The 360 degrees of the sine wave. Class-B would be 180 degrees, half a cyle, while Class-A is the full cycle.
360 means a complete phase?
So, in a single mosfet amp (like a szekeres like this)
It means that
-At Vin=0, Vg is at a value where the mosfet conducts
-At Vin=max, Vg is still at a value where the mosfet conducts
-At Vin=-max (negative peak), always the same...
Am I right?
What are the maximum peak values of a device's source line output?
It means that
Am I right?
Yes, you are right. A device (transistor, tube...) which operates in class A is biased so that a current flow anytime across it. This is not the case in class B, because usually positive and negative inputs of the source signal are amplified separately, in symmetric configuration : each of the two devices conducts about half of time. Other classes are unusable for audio, or more complex.
Regards, Pierre Lacombe.
Simply stated:
"Class A amplifiers use one or more transistors that conduct during both the full positive and negative cycles of the signal."
However class A is not limited to SS amps. The early Tube ones were all class A.
A simple introduction on various classes:
http://www.norh.com/docs/amps/
Simply stated:
- What is the definition of Class A?
