What is the cream of the crop for DIY tubes kits?
I've built two Elekit amps - the 879S and the TU 8300R. This has all been a work up to building a dream amp of some sort but really, it's become quite addicting in it's own right: building an amp from scratch and seeing something come to life.
That dream amp (kit) so far is the ANK C-Core interstage 300B Monoblocks. First of all, they are phenomenally gorgeous - audio porn at it's finest, never mind the specs.
What is your "Lottery amp"?
Dave
I believe that with tube amps you can often build things from scratch rather that building a kit. The main reason to use a kit would be if you're new to electronics / soldering AND you want to build a complex circuit with complicated power supplies etc.
The ANK 300B is not such a complex beast. It has lots of flashy parts and is super expensive (if not overpriced). If you're interested in a (parallel) 300B with interstage, take a look here:
I'd suggest you choose your design, then source the parts you like (not the ones selected by some guy who set up a kit to earn money), and build the thing the way you like it.
Thx mbrennwa! Exactly what I'm looking for.
