C
CryingDragon
CryingDragon said:Carbon film? Ceramic? Witch is the best for amps?
Seeing as you'll likely get recommendations of everything from carbon composition to bulk metal foils, the only way to answer that in a way that will have any particular meaning for you, is to say "Whichever resistors you like best."
se
C
CryingDragon
CryingDragon said:that works LOL. BTW what kind are those green ones you can buy at radio shack? polyester?
Er, green ones? Polyester? Are we talking about resistors or capacitors?
se
C
CryingDragon
CryingDragon said:Sowwy kinda jacked my own thread thereI ment caps i'm looking on digikey for some small value caps 2PF to 470 PF and i can't seem to fine one brand that has them all it making me mad!
Schmashy!
Ah! Ok. Now we're on the same page.
Damn, 2pF? Hell, just take a couple inches of insulated wire and twist 'em together. What sort of circuit are you working with that needs a specific 2pF cap?
Anyway, <a href="http://www.welbornelabs.com/">Welborne Labs</a> sells some nice Wima film caps starting at 100pF. For much lower than that you'll probably need to go to silver micas or ceramics.
se
C
CryingDragon
Heh, those nice 1ppm 0.1% S102C resistors can go for $17 each. Be careful what you ask for when you use a word like "best" in this crowd.
Might be better to ask "what is the best value" within X budget.
Personally, I'd use the metal film. Make sure the wattage is appropriate--a lot of tube amps need some 1-2W resistors in the plate loads. Some people feel carbon gives that authentic (noisy?) vintage sound.
- What is the best resistor?
