I have a hollow plastic TT base that seems to pick up and transmit noise.
What can be used inside the base, to minimize feedback. I was thinking about building a 3/4" wood box snugly around the outside of the thin plastic body of the turntable. Any ideas would be great.
Mass Loaded Vinyl like
https://acousticalsolutions.com/product/audioseal-sound-barrier/ is easy to cut and glue, its cheap enough to experiment with. If you can find a car audio installer they might even give some offcuts?
You didn't say what the turntable was, but most plastic Japanese turntable have a thin Masonite (hdf?) bottom cover that could do with damping
regards
james
regards
james
If it's mass loading and deadening like you might use in your car to stop the panels drumming/flexing....
Dynamat or dynamat extreme or aluminium/bitumen flashing tape. All are self adhesive.
DYNAMAT Sound Deadning Xtreme Extreme 1 Sheet 270MMX450MM | eBay
J.
J.
I have heard that Dynamat melts over time, it sure looks like the right stuff. I am also replacing the Masonite plate with wood. Thank you for all of your ideas. The TT is a Sony PS-LX5 and other than the fact that I can't get a spare headshell for less than $80 it works very nicely for me.
Decades ago when I had a plastic direct drive Yamaha TT I loaded the base with plastacine (could use Bluetack but expensive.) This made a massive difference to the feedback and improved the sound quality.
- Analogue Source
- What is the best deadening material in TT base
