Hifinut,
My local bunnings i believe, wont be any help to you, its in Kalgoorlie, Outback Australia! did you ask if they can get you some?
At worst i would try a plasterboard/insulation type place
these guys might be able to help you....they are helpful for the DIY home renovator
http://www.plasterbrokers.com.au/index.html
Svante said:
I'm not sure I should answer that , since I really don't know other than by hearsay, and also since there are several types. But guessing/speculating I'd say it is more isothermailzing than damping. More like polyfill, that is.
Open cell foam and polyfill are almost always used together so aren't they complementing each other?
Madisound in the US sells wool for $10.50/lb, Acousta-stuff for $9.50/lb, polyfill for $3.60/lb, and polyester batting.
Wool is unique; because it is made up of overlapping scales, it has more air friction by far than the synthetics. Acousta-Stuf attempts to do something similar with many fine crimps of the polyester strands. It is about 1/2 way between wool and normal polyester in effectiveness.
Bugs don't munch it though.
