I’m working on a 6sl7 - 300B stereo amp and need some advice on the best way to configure the power supply.
I plan on running the 300B’s at 365 B+ (300V -61V 60mA) and the 6sl7 in SRPP at about 365V.
For the psu I have two 7H chokes and four 30uF oil capacitors to work with.
What’s the best option for the psu
1. LCLC config (7H,60uf,7H,60uf) with one B+ for all
2. LCLC plus left and right RC config (7H,30uf,7H,30uf) for B+ and then (R,30uf) for Right B++ and (R,30uf) for the left B++
I understand that with config 2 I will have more flexibility and way less ripple for the 6sl7’s, but the cost is 2 times more ripple at the B+
How much ripple is allowable on the 300B’s running at 360V?
With those components, I'd use L then 30 uF, L then 60 uF, and RC for the first stage. Crosstalk will be much less if they are isolated from the output stage. Assuming that the output transformer is 30:1, you'll need to be below 30 mV (RMS - about 100 mV p-p) of ripple to be below 1 mV at the speaker.
Tom,
Just so I understand: I use 3*30uf for the LCLC stage for my B+
and add a RC stage (with the 4th cap) for the B++ (both Left and Right) ?
I can fit in 2 more 30uf if needed...
That way I would have a total of 120uf in the LCLC stage and still have
left and right B++
-Scott
left and right B++
-Scott
Yes - the first stage needs better filtering, because hum here will be amplified by the output stage. So it needs to be about 10X better.
7H:30 uF:7H:60 uF shows about 30 mV p-p ripple in PSU designer - should be good enough for the power stage.
