what happens when u change the clockfreq in a cdp
may it be a stupid question.
im going to build a new clock for a cdp with separate psu. but its a limited supply of crystaloscillators where i live it seems.
im supposed to have 16,9344 Mhz, well atleast thats the original crystal im going to exchange.
the closest they stock at the place i order from is 16,384 MHz
will it work? what happens when you change this value?
the psu in schematics is based on a 7812 and an AD797 op. any opinions?
or will a regular psu with a 7805 work?
It will work and the music will be slower 3.24%
Are you joking 7805 is for 5V supply 7812 for 12V.
I can send you a 16.9344 MHz crystal.
Contact me by email.
hello!
aha! so thats how it works. so if i put in a 8mhz it will go half speed?.
3,24% sounds to much. gotta find the right one.
well the regulators i was mentioning is for driving the XO witch im going to use instead. as i understand they need 5VDC.
Re: Re: what happens when u change the clockfreq in a cdp
I'm under the impression that it will not work at all; the CD drive will not be able to read slower. Correct me if I'm wrong.
3.24% is actually livable... NTSC Film -> PAL conversion results in 4.27% faster picture and sound. :smash:
Choose whichever voltage your device needs. If it needs 12V, give it 12V. Same goes for 5V.
Your wrong.....
Elektor made a pcb in the early days of cd (1988). It had a var clock, so you could change the speed of the reading of the cd. Compared it to the speed adjustment of a record player.
Speed variation was -20% to +15% without problems. -50% also worked for playing, but skip and search did no longer.
It was designed for the early philips players, first and second chipset.
guido said:
Your wrong.....
That's pretty cool. So the pitch of the singer will also change with the sampling rate?
Does it work with SPDIF out to a DAC with reclocking?
