I was winding inductors for my speakers. I got done with one of the two 12 mH inductors I had left, when I realised that I didn't have enough wire to wind the other one (judging by the weight of wire left). I had 30 lbs. of 12 gauge magnet wire and according to calculations I only needed 24 lbs., but I guess I didn't wind them very neatly and therefere thighly enough and I ran out of wie.
So I will make the 12 mH inductors ferrite core instead. The designer of my cross-over (alvaius) recommended ferrite core anyway.
I've heard that only some ferrite is suitable for winding inductors. I only read two things on this forum about choosing cores: You should look for ferrite to use for inductors, look for ones with high "H" and B" values. Also Marcus wrote that "When choosing your core you should look at the data sheet and make sure that the BH-graph is linear and that it has as small as possible hysteresis."
My question is, is this all I need to know about choosing ferrite cores? And where can I buy ferrite cores on the internet or in what stores in general?
I meant ferrite rods, I think ferrite cores are circles. After seaching the web I found this website that sells ferrite rods http://www.cwsbytemark.com/prices/rods.php. Are these rods any good? I think I need the type 33 rods, but I'm not sure. Any imput, anyone?
Ferrite cores come in various form factors. Typical are rods, toroids, Pot Cores (in various forms), E cores etc. The field is huge and the biggest manufacturer is www.mag-inc.com. What is also interesting is high-flux materials and KoolMu where the latter has an integrated air-gap. Magnetics also has software for designing inductors on the site I gave.
For various reasons, Ferrite's do not seem to be used much in speakers, and I assume this is mostly a cost issue + unfamiliarity with selection process (there is a huge choice). What you can do with the rods that you have already made is to add something to them to reduce the magnetic reluctance (shorten the path).
Petter
Petter
You can probably get decent results using a low carbon steel rod(say type 1006) of about 1" diameter as a core. The issue you get with a solid material is the volume resistivity issue and some energy is dissipated as eddy current losses. A better way to make a core is to use sheets of low carbon steel with thin insulating material like varnish or paint between them. This reduces eddy currents.
Low carbon steel has a flat B-H curve (low hysteresis) and is much more easily available than ferrite cores.
What you want in a core is high permeability and low volume resistivity. Basically the permeability reduces the number of turns of wire you need to make the inductor (air has a permeability of 1.0). Core materials are made for specific frequency ranges because the permeability of the core materials varies with frequency. You wouldn't want an inductor that changes value with frequency, would you?
You also have to worry about saturation, making the core big enough to stay on the linear part of the B-H curve. The permeability changes with signal level as well....
All of these reasons are why it is cheaper and easier to buy an inductor - or make an air core one (as you attempted). I'm having trouble not picturing the scramble-wound 20Lb pile of wire you must have 😉
The problem with winding your own cored inductor is that it is likely to be a trial and error process unless you can get good information on your core material's properties....
Thanks for your imput, I think I will go find those sheets of low carbon steel and paint them and roll them into a core.
Do you know where I can buy some of these low carbon steel sheets? I know where I can get steel sheets from (Home Depot), but I don't know if they're low carbon steel sheets. And when I ask them if they're low carbon they won't know what I talking about, I'm willing to bet.
Also do the ferrite rods have to be 1" in diameter cause I could only find .5" diameter ones?
I tried looking for those sheets, but couldn't find ones thin enough to bend. And I would have to order them just like the ferrite rods. But like I said I might order them anyway cause the only rods I could find are .5" in diameter.
BTW, the core can be square - you would not have to roll the sheets.
Say you bought 18 gauge sheet - this is .048" thick, so you would need about 20 pieces that are 1" wide and just a bit longer than your coil to make 1" thick core.
A 1/2" core may work just fine - you might just have to try it.
Do a search on the web for "inductor design"
Some of the search terms could be "amp-turns", "magnetization curves", "magnetic properties", "saturation", "flux density", "reluctance", "permeability"
A fairly good page:
http://www.fnrf.science.cmu.ac.th/theory/magnets/Producing wound components.html
A fairly technical page - subject is magnetics, not just coils:
http://www.ee.surrey.ac.uk/Workshop/advice/coils/terms.html
A fairly good page:
Thanks for the tips RON E
I got a whole bunch of 1x1.5" pieces 16 gauge low carbon steel. Some guy cut them and gave them to me for free when I offered to pay.
I painted them with automotive primer and painted then with rustolem enamel. I will soon glue them together and begin winding. Only I don't know how I will wind all the way to the edge. I can't use a wooden dowel and some wooden circles with holes in the middle and nails though the dowel to hold the circles in place; like with the air-core ones. I will have to think of something else.
What the difference between iron powder rods or ferrite rods in terms of winding inductors?
I just got some ferrite rods.
The iron Powder type has lower permiabilty and that makes them saturate at higher current,In other words -less distortion at high power.
One more thing . . .
What will saturate quicker if I use the whole 4 inches of each ferrite rod to wind my inductors or if I use say 2 inches of each ferrite rod I bought to wind each inductor and then cut off the rest? My guess would be the more ferrite there is the slower it will saturate, no?
Also this is not that important, but I was wondering if what I'm making is called transformer type inductor or is that something totally different? Is it a better inductor at 12 mH than what I'm attempting to do?
If you`ll be using 2 inches of ferrite on the same spool of wire you`ll get less induction,you`ll have to add more wire to it,and that will also add dc resistance to the coil.
Remember,air core is more linear then metal core,you must consider several factors when designing a metal core inductor in order to use it in it`s linear area.
I wish i knew more about it.......
Cored Inductor/Transformer design is very complex - I am certainly no expert; just someone with a passing interest and a fair amount of physics background. The complexities are the reason you don't see more people DIYing cored inductors.
That said, saturation probably isn't dependant on core length, rather core area and the number of turns and the current through the coil.
Some cores are made to hang out somewhat from the inductor and thus they achieve better flux linkage and higher inductance, or so I've heard. Perhaps leaving a half inch or so of bare ferrite on either side of the windings would be a good idea.
You can buy decent quality ERSE 12mH cored inductors from PArts Express for ~$15. Save the 12ga. for something simpler/smaller....
Funny the designer of my inductor, alvaius, said the same thing, but I already ordered those rods.
- What ferrite cores are good for winding inductors?
