I'm interested in what users of this forum would considerable desirable for a subwoofer module (ie custom subwoofer, amplifier, enclosure, etc) around the $1000 price point.
Things to reflect upon:
Would you be interested in a completed subwoofer module around the $1000 price point?
How large would you (or your significant other) tolerate?
What enclosure shape would you desire, ie cube, cylinder, etc?
How much power would you want and in turn power handling of the subwoofer?
How large of a subwoofer driver?
How large of Voice Coil?
What do you think needs to be improved in current subwoofer offerings?
Transfer function?
Ported, Sealed?
Continuous output capability, transient output capability?
What signal processing features?
etc.
Thanks, Thadman
Transfer function?
Ported, Sealed?
etc.
Thanks, Thadman
For home use, 50x50x50cm
cube is fine
Well, 120dB/1w/1m@20 Hz would be nice
doesn´t matter, as long as it does the job
Se above.. VC diameter is not much of a "power factor"...
Hard to say, there are so many variations... IMHO precision is the less improved, most marketing people seem to focus on watts, then hz (trasnfer function) oder driver size...
Transfer function?
20-200 Hz
Ported, Sealed?
Don´t care, as long as it´s done well. Chubby, growling ports is nothing I want to hear in a ported box
That´s not important, it´s what marekting will put on the box.. If it does 120dB@20Hz with lower than 5% THD, I´m satisfied
Here is the part where it gets interesting.... The upper features are not so hard to achieve and it´s not really new.... Nice would be a room correction, that really works and is done with a lot of brains. Amping of course should be class-D with power factor correction and all the filtering should be done via FIR-Filters....
ok, not sooo difficult, but here it comes:
If the DSP would be run by open source software (e.g. Brute FIR) and if a SDK would be available... that would just make my day, I´d even spend more money (instead of building it myself )
cube is fine
Transfer function?
20-200 Hz
Ported, Sealed?
Hi there!
What do you want in a subwoofer module? Post #1
Yes
Up to as big as a wardrobe
Cylinder is the best, but there arent many options. I decide as I go along.
500W is always enough
I need a flat frequency response at at least 100db.
15" no more no less (for music)
I use 100mm
The damping of the enclosure (and the price compared to DIY)
Ported, Sealed?
You kiddin me? Horns are the best. If not possibloe, I take transmissionline or Dipole but I will never use boxes again.
whatever
Nice Tube Amp, and of course bass traps all over the room (especially the corners)
etc.
Thanks, Thadman
Yes
I use 100mm
Ported, Sealed?
whatever
etc.
Thanks, Thadman
