What do you think about this LM3886 desigh?
Hi
A friend of mine just gave this LM3886 schematic to me. Probably not the most simplify gainclone I ever saw... I need some feedback from anyone who thinks there's improvement can be made....and do anybody think this is a good design for the LM3886TF ??? Advice and recommendation is much appreciated...
AndrewT said:
I suspect the designer did not know what effect each component had on the performance of this amp.
If the builder does not understand the operation of this specialised schematic then steer clear.
I would not entertain it.
wow...that much....!!!
you mean a simplified LM3886 circuit is better than this...?
It's easy to explain how it will sound, by just looking on the negative reaction. It will boost the frequencies under 100Hz, it can literally blow your speakers. This might be a poor attempt to create a subwoofer amplifier.
Depends on your speakers and your music taste.
With 4 Ohm speakers ±35 V is too much, with 8 Ohm its okay.
The schematics above all show very little smoothing capacity, which makes the amplifiers suitable for high- or mid-range active speakers or for people, who do not ask for too much bass performance.
You should add the Boucherot cell to the output. It costs little, has no influence on the sound, but can prevent the amplifier from oscillating.
The datasheet is recommended reading. All external components are shown and explained, so that you can assess for yourself, which components to use or to leave out and which size they should be.
