What do you guys think of this IR volume control?
No you dont need a pot, it comes with one. It comes with everything you need but the 12volt power supply. Id just pick up a small 12v switch mode on ebay ment for a notebook or something similar. The power supply can be as crappy as you want since its a passive volume control. The signal never comes into contact with the power supply. The 12v or what ever will just be converted to 5 volts on board and regulated
PS: Looks like it switches inputs too.
One comment on the first unit:
The inputs are poorly positioned with respect to panel mounting via the pot retainer nut.
The wires may be pushed against the panel.
Evenharmonics, does the MV04 support manual mute?
