What construction flaw factor causes a Western Electric "B" grade 300B tube?
Someone needs to do a curve trace of one of these "high" current tubes to see what you are getting. If the grid or filament are off center, then one would expect to see "roll-over" or flattening of the curves at the HV end, giving high 2nd Harmonic.
I'm planning on doing that. But I have to learn how to adjust the parameters in the eTracer, if I have to at all? Do you think I can just choose the file for a 300B and trace it like a normal 300B? I would think I should tell it to run through a wider range of bias values, of course leaving the plate V values the same. Maybe I'm over thinking it and I should just trace it using the parameters of a normal 300B, then decide if I want some curves outside the normal ones added.
I might give these B-stocks a try in my Elekit TU-8600R 300B SET, which runs 360V plate voltage.
Is there any reason to buy the Hi-IB over the cheaper Low-IB B-stock tubes for the Ekekit, which has the "new active automatic bias"?
"Unlike traditional cathode bias, where a resistor and capacitor are placed at the cathode to set the bias voltage, the TU-8600R employs a separate, dedicated bias power supply and an active circuit. This circuit senses the plate current (with the current detection moved from the cathode side to the B+ power supply side for improved sound quality) and actively controls the grid voltage to maintain optimal bias."
You should check with Viktor. I know he advised against using Sophia 300Bs in the 8600. And with good reason. A friend of mine kept trying to use them in his 8600 and broke it--twice.
If that amp automatically adjusts it's bias using normal tubes it may not have enough "range" to auto-bias these back to the set bias. It may "keep trying" but never reach the set point because the designer never expected someone to plug in a tube like this, its range of auto adjust may only be +/- 5% or so. With a direct bias amp where you control the bias fully is probably the main candidate for these tubes I would think.
