Story short: Have plans for a big 4-way system based on the JBL 4675C. (2226H + 2445H/2360) + 2x18PP sub/supertweet.
My main worry is the 2226H in mid-duty. I therefore bought HQ 12" midwoofers to get a benchmark. I now worry about having taken dispersionissues too lightly, and might end up with expensive spare 12" woofers. Another angle would be to consider a much smaller (physically) system with the 12" + CD/WG/Horn.
If we leave the 4765C-system out of this discussion (- alternative 15"s is an option here):
What compressiondriver (1") + waveguide/horn would be your choice? Woofer is PHL 4550, and would likely be HPed @ 80Hz to a sub-system. Active DSP for XO, EQ etc. For example: SEOS-12 + B&C DE250 seems like an option, but have noticed that W. Parham was less impressed (due to depth of WG?).
For the record: A system based on the 2360-horn is still the main plan, but I think it would be interesting to investigate a smaller scale system too (less than 6 ft/180cm high/3 ft/80 cm wide) - especially since there will be a learning by doing-period anyway. Gameplan would then be: Subs + 2,5 way 12"/1" CD WG/horn. I know: Should have bought some 10" instead.
Appreciate thoughts
Regards Johan Rosberg
Appreciate thoughts
