Hi, how are you
I want to buy this horn tweeter: Amazon.com: Seismic Audio - Single 4x10 Horn Tweeters with Driver PA/DJ Speakers - Replacement: Musical Instruments
With this Lpad: 100 Watt Mono L-Pad | 50-070 (50070) | Distributed By MCM
Im not very sure of what capacitor to buy, 4.7 Bullet Tweeter TMC Mylar Capacitor 4 7uF x 250V 2X Pack True Voltage | eBay
or 6.8 capacitor?
Note: Is for a custom cab with a damaged tweeter, im buying the Lpad to manage the level mismatch.
or 6.8 capacitor?
There is not enuff information given on the tweeter to be able to choose. As well the extention/XO on whatever driver is mating up to it makes a difference.
You might want to look at MAdisound/PE/MCM etc for a tweeter with more adequate information
dave
dave
3k at 8 ohms if your only using 1 capacitor for a 6db decrease I would go for a 2.2uf if you want that horn to last, that would cross it over around 9k, so -3db would be 4k, -6db at 2k
It would be better to use a 12db circuit which would involve an inductor and capacitor and wire the tweeter out of phase.
Jsixis, you got that all wrong.
If the tweeter were actually 8 ohm (unlikely), 2 uF would give an F3 of 10k (down 6 dB at 5k, 12 dB at 2.5k). 4 uF halves those values.
dave
dave
Hi, thanks for the response. So the 4.7 cap wont work? This is for a 2-way cab, im looking for a cheap 4x10 tweeter horn. I was thinking that putting a 4.5 uf will make the tweeter close to the bass driver, because i dont have a mid freq driver. I think the driver is close to 3khz. I wanted to put the tweeter close to 3khz, but maybe im confused with how it works.
dave
even better if you want the tweeter to last
Start with one of these, then ask again:
Amazon.com: loudspeaker design cookbook: Books
Certainly your question will be a different one. 😉
- Design & Build
- Parts
- What cap for this horn tweeter for a 2-way cab
