I got 2 pairs of Motorola MJ2501 and MJ3001.
The markings are MJ2501-1, MJ3001-1.
Can I use these to make some solid state amps?
Then, which amps would you suggest?
MJ2501/MJ3001 is a complementary 10A darlington power transistor.
The max. Vce voltage is 80V, and Power dissipation is about 150W.
So it can be power stage output transistor on 50 ~ 150w OCL power amplifier. but should be carefully using because the value of hFE is very
high(about 4000).
high(about 4000).
