What can cause a transformer hiss?
I have an old Kenwood KAC-7285 and when I turn it on a medium loud steady hiss comes from the transformer. I tested all transistors, di0odes and resistors and all is good. I did inspect all caps and none are leaking or any signs of damage. If anyone who might be able to tell me what to check I will be so grateful.
Jean
Tomchr: It's a Monoblock Class AB.
Perry: Yes I have a scope. No you would not hear it in the trunk and it doesn't get into the audio.
With the amp put together fully you can hear it clearly if TV is off. If you know what you're listening for you can hear it over the TV .
I found the problem, it was a transistor Q13. I thought I tested them all but these hang off the PCB and I didn’t notice it. It’s the most simple’s things that can be the hardest things to fix.
Thanks for your help.
Jean
Completely gone. I do have to say it was loose in the socket, solder was broke around Q113 pins plus I do run the power supply at 11v and 2.5 amps for testing. I don't know if that plus Q113 would have anything to do with it.
Jean
