Yes, it seems like the transformers are center tapped.
I'm no expert for sure, but...
That puts you somewhere in the Aleph 5 range too (CLC/CRC). I doubt you would have enough current even as a dual mono though. Maybe you could parallel a pair of transformers, not directly, but after a bridge on each. Maybe high pwr .5 ohm resistors after each bridge could help them share better??? ( have no idea if this would be OK, waiting to get flamed)
If dual secondary maybe you could parallel the secondaries and use a transformer for each pos and neg rail. (same disclaimer applies)
How about putting the primaries of two transformers in series and use the full voltage secondary taps as they would now be 30v..and run a monoblock? (um..🙄 maybe)
I like trying to find a place for the stuff I've got kicking around, it's good for the environment 🙂
Thanx,
You have geothermal power - but even it cannot be tapped continuously and the heat mass below needs a break to replenish it's capacity.
So it appears you have 330VA 60V CT trannies , 8 of.
One will make you a probable +45V,-45V supply (unloaded) with good stamina for a stereo 100W/channel R2R amp running Class AB - typically drawing maybe 25W of geothermal power. Sweet.
7 more for your friends (you'll need a big stick).
