what cable when soldering on capacitor legs and pcb
bought new caps for my old rotel rb990 bx.
they are to big to be directly soldered ont pcb stuff in the way.
so i will put them somewhere else near were they would be offcourse.
someone said i should use low line cable why is that?
i think i can use normal power cable like ekk or is it a bad idea?
dont know what the difference is.
Hey there,
as capacitor technology has improved over the years, it is very unlikely that a current production cap is significantly larger than an old one. At least if we're talking about the same specs for the replacement cap.
Keep in mind that the rest of the power supply might not be up to the task of supplying vastly increased filter capacitors.
Greetings,
Andreas
