What are these called and where can I get more?
Hello everyone. I just got a pair of renkus heinz dual 18 subwoofers and some of the driver retention brackets are missing. Getting the bolts is easy, but I can't find the brackets or whatever they may be called. I've seen this driver mounting technique in bag end cabinets before. I'm looking forward to any information. Thanks
Try vendors that cater to Pro Audio, or maybe Maidsound or Parts Express. Plus there is always McMaster-Carr.
If all else fails, make your own. They appear to be simple aluminum extrusions, which are available from metal vendors. You can cut a length of extrusion, drill the hole, done. Don't cut your fingers off, please; use proper technique, clamps, etc and don't even think about doing it without eye protection.
Edit: drill first, cut second.
