what amps do i need for this speaker config?!?
Hey, I would like to know what kind of amplifiers would i need to power the following configuration of speakers!
CASE 1:
6 x tops (3 on each ch)
LF: 2 x 12" 1000w 8 ohms
MF: 4 x 6" 800w 8 ohms
HF: 2 x 2" 200w 8 ohms
3 x dual 18" subs (1000 w 8 ohms each driver)
CASE 2:
same as case 1 but with 4 x tops (2 on each row) and 2 x dual 18" subs
I understand I need to bi-amp the system so please let me know what kind of amps i would need for both the tops and the subs in each case, I am looking for general amp specification that would match this speaker config but make and model would also be helpful.
Is this a PA setup? I think you also need to provide a great deal more information about the speakers.
You should note that most speakers rated for powers such as 1000W are vastly overrated by their makers/sellers and will not handle the specified power, even for a short time. Notwithstanding, do you have a hearing problem that you need that much power?
My three way speakers are tri-amped with LM3866 chips (about 55W max) and they are deafeningly loud long before full volume.
