Hi
I am planing on building a sub for useing it for home theater and music with a bpa200 amp. Will this VISATON W 300 S 8 OHM be suitable??? In a vented box, what will be the best F3 ?
Here is the T/S :
W 300 S 8 OHM
Rated power 150 Watt
Maximum power 200 Watt
Nominal impedance 8 Ohm
Frequency response (-10 dB) fu - 4200 Hz
(fu: Lower cut-off frequency depending on cabinet) .
Mean sound pressure level 92 dB (1W/1m)
Maximum cone displacement 28 mm
Resonance frequency fs 23 Hz
Magnetic induction 1,1 Tesla
Magnetic flux 1400 µ Weber
Height of front pole-plate 8 mm
Voice coil diameter 5 cm
Height of winding 1,85 cm
Cutout diameter 28 cm
Net weight 4,5 kg
D.C. resistance Rdc 6,7 Ohm
Mechanical Q factor Qms 1,65
Electrical Q factor Qes 0,42
Total Q factor Qts 0,33
Equivalent volume Vas 340 l
Effective piston area Sd 507 cm2
Dynamically moved mass Mms 57 g
Force factor Bxl 11 T · m
Inductance of the voice coil L 1,8 mH
Here is the T/S :
W 300 S 8 OHM
Net weight 4,5 kg
The box will be pretty big (relative to what I call big, which is bigger than 60 litres) for vented.
With a box max 70 liter i will be ok but i think the F3 is not the suitable for a home theater usage.Is it?😕
With a 70 litre limit you are going to struggle to get a low enough F3 for anything, and the response in a vented box at least will be very peaky.
This is a job for a sealed box and Linkwitz Transform.
Hi richie00boy
Thanks for the help.I think i will go with a beter sub.Have a look at this infinity.The only disadvantages is it coasts 50euro more than the visaton and i am afraid that the bpa200 will run hote with a 4ohm load.I think this one can go 20hz F3 in vented.
Kappa 120.3se 12" Woofer
VOICE COIL DC RESISTANCE: REVC (OHMS) . . . . . . 3.56
VOICE COIL INDUCTANCE @ 1 KHZ: LEVC (MH) . . . . . . . 2.13
DRIVER RADIATING AREA: SD (IN2) . . . . . . . . 76.11
SD (CM2) . . . . . . 491.00
MOTOR FORCE FACTOR: BL (TM) . . . . . . . . 15.51
COMPLIANCE VOLUME: VAS (FT3) . . . . . . . . 1.96
VAS (LITERS) . . . . . 55.61
SUSPENSION COMPLIANCE: CMS (ìM/N) . . . . 162.44
MOVING MASS, AIR LOAD: MMS (GRAMS). . . . 193.00
MOVING MASS, DIAPHRAGM: MMD (GRAMS) . . . 186.74
FREE-AIR RESONANCE: FS (HZ) . . . . . . . . 28.43
MECHANICAL Q: QMS . . . . . . . . . . . 6.82
ELECTRICAL Q: QES . . . . . . . . . . . . 0.51
TOTAL Q: QTS . . . . . . . . . . . . 0.48
MAGNETIC-GAP HEIGHT: HAG (IN) . . . . . . . . . 0.39
HAG (MM) . . . . . . . 10.00
VOICE-COIL HEIGHT: HVC (IN) . . . . . . . . . 1.46
HVC (MM) . . . . . . . 37.00
MAXIMUM EXCURSION: XMAX (IN) . . . . . . . . 0.53
XMAX (MM) . . . . . . 13.50
- Subwoofers
- What about this one:
